Plugs on Front Differential, Where is Fill?
Good stories (dipstick, hahaha) Here's my quick front diff story. After I bought my truck this past summer, I did as you and changed all the gear fluids. Starting from the back and working my way forward. Well, I got to the front diff and started to remove the filler plug. It was quite grungy and I couldn't tell that it was a hex bolt. I 'assumed' it was like the other plug bolts and a 17/19 whatever mm standard bolt that the previous owner had rounded off. I saw the drain was a hex but thought it was just a replacement so I dremmeled a slot into the fill plug to use a large screwdriver to break it loose. Felt like a complete idiot when I got it out and cleaned it off........
06-01-2021 02:51 PM
jerusry
10-19-2015 06:28 PM
09-04-2015 10:27 AM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 08:15 PM
