Please help URD FTC wire color question.
Old 09-28-2006 | 12:13 AM
Fingers's Avatar
I have a 1997 Toyota HILUX SURF (4runner Limited), automatic transmision. Everything on the URD FTC connection diagram matched with one exception. The wire located on Plug B Pin 8 is solid red on my truck. The instructions identify this as the MAF sensor wire but say it should be Red w/white stripe. There is a red w/white stripe wire in Plug B, Pin 18. Anyone know which I should connect the Green w/yellow stripe and the Violet wires on the FTC to?
Perhaps someone knows how I can id the MAF sensor wire from another location.
Thank you for your help, I am stuck until I can get the answer.
Old 10-01-2006 | 01:40 PM
Tragic Drive's Avatar
You can call Split second and ask specifics ask for Mark Amarandos (949) 863-1359.
coryc85
09-09-2015 07:24 AM
09-04-2015 10:27 AM
Gevo
07-29-2015 12:15 PM
88yodabasket
07-13-2015 02:32 PM
Johntom240
7
07-13-2015 01:18 AM
