Last edit by: IB Advertising
Browse all: Toyota 4Runner Exterior Guides
- Toyota 4Runner 1996-2002: How to Install Rearview Backup Camera
Step by step instructions for do-it-yourself repairs.
Pioneer 4100 HU Installed with Cameras
#41
Both cams should be listed either as "normal and/or regular view" or "reversed view".
For example, here's a Normal View camera currently listed on ebay - Item number: 350251202511
And here's a Reversed View camera - Item number: 350240665928. Here's another: 160364261389
The Reversed view cams are pretty readily available...it's the Normal view cams that take a bit more searching to find (these are not in high demand).
#42
Well the camera is wired to always be on when the ignition is on, and the video signal connects into the back of the HU. I have the headunit tapping into the trucks reverse wire, so when the truck is in reverse it automatically shows the camera until it is put into drive. I can also manually select the rear camera source as well.
#43
#44
Oh sorry... The camera is wired. The wires go into the tailgate behind the license plate and then follow the other wires at the top left of the gate (wiring it inside the tailgate and not getting in the way of the power window was a little tricky) into the truck and along the floor (under the carpet) on the left side of the truck all the way up to the headunit. So no exposed wires.
#46
LOL, I've actually thought about adding one. I can't remember, did you get around to adding one to your system?
BTW, I'm still trying to decide if I want train horns or not. A guy here at work installed them on his '08 Tundra and they sound insane.
#49
Yep
Here are a couple of videos:
Near miss when a lady lost control during braking right in front of me....
http://www.youtube.com/watch?v=9CnngxifPjg
An NYPD Cruiser reversing blindly into cross traffic, hitting a Honda CRV....
http://www.youtube.com/watch?v=z1-JrNYrpeU
#50
Pulling this thread out of memory. If you were to add, say, six cameras total. What sort of splitter would you use for the video signals to enter the rear of the display?
#51
Do you want to record?
If so, do you want it to record all cameras simultaneously or just one at a time?
A rotary switch will work fine for just viewing or recording one camera at a time (using a single channel DVR), but if you want all to record at once, you'll need a multi-channel DVR.
In that case, the DVR itself will split the recording screen for you.
Here's a short vid of my (currently) 5 camera switched system using a single channel DVR (6-way rotary switch)
http://www.youtube.com/watch?v=cYM973XTNa8
I plan on adding another 4-channel DVR soon.
#52
Recording not necessary; same functionality that your video shows, just displaying the different cameras.
I understand the 6-way rotary switch sending power, just not clear on the composite video end of the setup.
#53
The 6-way rotary switch doesn't send power, it just connects any one of the 6 inputs to the output source.
Here's one that I made using parts from Radio Snack
It basically has 6 inputs with a single output (I added a piggy back output for external monitor use)
About 5 bucks in parts and bout 10 minutes to make.
#54
Ohh, I guess i'm getting confused between the way you did it, and the way that Rockslide's diagram on the first page demonstrates.
Soo, if you're using the 6-way for video selection, you're running separate power leads to each camera?
#55
Nope, since I have a DVR, I run all of my cameras 24/7.
They pull less than ~250mv each, so I can go weeks at a time without draining the main battery.
If you only plan on using them for viewing, just connect them all to a single relay with an ignition source.
#56
I guess i've just never cut a composite video cable in half before...it just includes your standard Pos/Neg leads? Solder those to corresponding pins on the rotary, and the output comes out from the middle, correct? It didn't occur to me that it would carry the video signal.
That does sound pretty simple...
#57
Yeah, composite video is pretty straight forward.....just two wires.
Two from the center of the switch hub for the output and two opposing on the outer ring for each input.
Cutting pre-made cables can be difficult to work with due to the way they're made, so I just use regular speaker wire and solder them to phono jacks.
#58
In my diagram, I ran one power lead from each camera to the switch itself. Then one power wire from the camera to the relay. The switch is just there to select which camera to operate.
#59
#60
You're making it too hard for me to keep pace! Nice work.
BTW, what cameras are you using for the side shots? They seem to be producing more vivid colors...something that lacks in my cheap $20 ebay cameras.
Now once you start filming/recording in 1080p, we're all in trouble...
