pinions?
pinions?
What is the differance between 2 pinion and 4 pinion dif? I can't picture it. Also where is the best place to get a third member rebuilt? I have a 92 4 runner and it has high miles but otherwise exc shape. Starting to whine pretty bad and the last guy has already had it retorqued according to the receipts that I got. It has about 30 degrees of free play at the pinion. That seems like a lot to me.
dont realli kno the difference between the two types of pinions, but i kno a place that does gears. i just recently busted my pinion and ring gear. i took it to a place called "performance 4wheel drive" . they did my r&p for $400. $200 for US Gears, not some cheezy "genuine gears" that 4wheelparts performance center sells (made in brazil or something. cheapy!!! ) and $190 for the labor. i took the 3rd member to them though.
Performance 4 Wheel Drive
9817 Park Street
Bellflower, CA 90706
562-925-0028
or try...
Gear Shop
2648 East South Street
Long Beach, CA 90805
562-634-1396
ugh... there was one in hawthrone too. i forgot the name.... ahhhh
9817 Park Street
562-925-0028
or try...
Gear Shop
562-634-1396
Pinion gear is a misnomer in this case, it's actually referring to the spider gears in the differential itself. 4cyl diffs have two spiders, V6 and turbo diffs have 4.
heres another gear places that does is real good.
South Bay TRuck & 4wd
Contact: Frank
310-219-0727
4621 W Rosecrans
Hawthorne, Ca
he works on all 4wd, but he focuses on yotas.
he uses US gears too, but he will install anyone u bring out buy.
Contact: Frank
310-219-0727
4621 W Rosecrans
Hawthorne, Ca
Thanks for the info.. I have found a place here that I have heard good things about. Anyway, I have found out that the 4.30:1 gears are toyota ownly to the tune or $750 for a gear set.
Once I found out if I will need a new set I may just go with new sets on both ends since it will cost the same. I need to now if any one knows of a good site with a couple of formulas so I can figure out how much my cruising RPM will be affected with a 4.10 or 4.88. I have 31X10.50's right now and would like to keep that size but may have to change. It runs about 3100 at 70 mph right now. I don't want it to run much higher than that on the highway. Anybody using the 4.88's with 31x10.50's or 4.10's? Also what is the ratio of 5th gear in the 5 speed? Thanks
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
Odin
09-26-2015 06:56 PM
justdifferentials
09-05-2015 06:52 PM
trailgoat
08-13-2015 05:54 PM
