pinging on 3.4l taco
i have a 2001 3.4l 4x4 xcab 5spd.
anyways, i am getting quite a bit of pinging. I notice if I use 89 then there is not as much pining... but its still there....... any ideas??
do the 3.4l usually ping a little?
thanks
thanks
thanks
thanks
Yeah... pinging is never "normal"...
Any chance that you changed your plugs to the "wrong" ones? Maybe something hotter?
Like InFlames asked, are you supercharged? Is there anything else that you've done to your engine - or not done! (dirty air/fuel filter, deckplate mod, ISR mod, ECT mod, etc...)
thanks
thanks
My 98 pings. More lately than normal. I wonder if the gas is getting cheaper? I didn't have many problems with 87 octance before
Last tank I bit the bullet and filled up with 89 octane. Much, much less pinging. It runs much better and smoother too. I guess I just start feeding it 89 at 2.09 a gallon :cry:
From: Far western Kentucky (transplanted from central PA)
if your fix is using 89 octane, then try alternating between 89 and 87 each fill-up from about 1/2 tank. see if the minor increase from 87 to about 88 reduces it. it could save you a few bucks.
Could also be clogged injectors and/or a dirty combustion chamber. Run some Redline SI-1 thru your tank. Best fuel system treatment ever. You'll find it at good, performance oriented auto parts stores.
Peace.
G
Peace.
G
With mine I know I have cleaned the MAF, did the seafoam thing and all but I still get the pinging. I do have a problem with a rough idle and I wonder if it's connected?
Originally Posted by Mikey
That's next on my list, I only have about 20K on them though.
nvwiggins
13
06-16-2016 04:05 PM
LCE_Performance
10-01-2015 02:03 PM
Toys4parts
09-26-2015 02:56 PM
Tacoma1313
08-17-2015 06:44 PM
