Philips Vision Plus H1, H3, H4, H7
Does anyone know what type is a direct replacement for headlights and foglights on a 4th gen? For those that did , is there any difference vs stock?
Low beam headlamp
9006
9006ST Silverstar High Performance Halogen Upgrade: The Look of HID: Whitest, Brightest
9006XV XtraVision Halogen Upgrade: Up to 20% Brighter
9006CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
High beam headlamp
9005
9005ST Silverstar High Performance Halogen Upgrade: The Look of HID: Whitest, Brightest
9005CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9006
High beam headlamp
9005
Cool, thanks for the reply. I heard Silverstars are really good but Philips Vision Plus are a little better. Do you know what type (H1, H3, H4, H7) though? Thanks.
I have vision plus headlights, and they are a little better than stock, though not as much as i had hoped. if they ever burn out, i'll have to try silverstars. regarding bulb type, the owner's manual should tell you what size bulb fits in the headlights, foglights. I'm sure someone else can chime in though if you can't find it. For 3rd gens, the headlights are H4s and the stock fogs are H3s, but it might not be the same for 4th gens.
Tacomas are H4, i assume 4runners are the same?
Russell
edit: check www.powerbulbs.com, they have bulb info for lots of vehicles
Russell
ok, im pretty sure then all of the toyota are h4, it seems most foreign vehicles (asian imports) use h4..... mine is really a sealed style 85 pickup its like 7x6" but i have a unsealed housing and h4 bulbs
my sisters civic uses h4 as well
Kevin444 said it right, they are not H1,3,4, or 7, they are 9006 and 9005. These are different lights altogether. I run the silverstars as my lowbeams and the phillips as my high beams, so I can't really compare, but I know that the phillips high beams are much brighter than my stock ones. The silverstar lowbeams are not that much brighter, just whiter and cause things to reflect back better.
I bought mine from here:
http://suvlights.tripod.com/suvlightscom/
They were friendly and quick, as well as decently priced.
As far as I have searched, they do not have the Vision Plus for the 9005/9006 headlamps.
I have the Philips Premium and while they are a tiny bit whiter than stock, they are not any brighter.
clok
11-19-2015 01:09 PM
kraegelb
20
11-22-2003 10:10 AM
