pcv valve on a 3vze??
Old 05-12-2004 | 07:12 PM
red 59's Avatar
I was wondering where if there is a pcv valve on a 3vze? Thanks.
Old 05-12-2004 | 07:26 PM
ChickenLover's Avatar
It's on the passenger side valve cover. It is very hard to get to. Most people will remove the throttle body and plenum to get to it. If you do it that way, you might as well give the tb and plenum a good cleaning. However, it is possible to replace it without removing these things but it is a real pain in the ass. Be prepared to spend some time on it. And you will need some patience. Good luck.
Old 05-12-2004 | 07:35 PM
red 59's Avatar
Part of it is coming from under the throttle body? Its a pretty thick hose?
Old 05-13-2004 | 04:20 AM
Amkeer's Avatar
You need to pull the intake. You might as well change the valve cover gaskets while you are there. You will need intake gasket, pcv hose, grommet, pcv and lots of patience. It will be a day job.
Old 05-13-2004 | 04:23 AM
shazaam's Avatar
takes 20seconds in a 5vze
Old 05-13-2004 | 07:44 AM
Dr. Zhivago's Avatar
Away
I think the engineer who designed the 3VZ-E is roasting slowly over a bed of hot coals for all eternity...
G
Old 05-13-2004 | 08:50 AM
Epic Ed's Avatar
He will be when I find him. Son of a...
smthwsn357
05-01-2024 08:28 AM
JHalcyonM
03-06-2019 09:37 AM
ManzDaKlown24
08-22-2015 11:25 PM
clok
08-01-2015 10:42 PM
