Passenger side coolant leak
O.k I need a little help. I have searched the archives and nothing comes close to this. I have a steady (1drop per sec) leak on the passenger side. Engine runs drop dead gorgeous. I have already had both HG replaced and this is nothing like that. It's close to where the ac would drip. So far the only wet spot I can see is the front of the tranny tunnel insulation. The fire wall appears dry. There are a few spatters on the engine but nothing that would lead me to think it was coming from that, just wind blown while driving, maybe. The tranny is dry and clean. I guess my question is can the heater core leak to the outside? Is there a drain hole or anything? I think it may be my heater core because when I turn on the heat I get a blast of coolant smell that lasts for about ten minutes and then either goes away or I don't notice it anymore. Has anyone had a passenger side coolant leak like this before. any help woulod be greatly appreciated.
Because it is a 3.0 you can hardly see anything through that bag of worms on the top. Let me know if there is a sensor or anything that my need to be changed. I'm going to disconnect the Heater core and ee if the leak stops. THat'll be me first test.
Thanks in advance
Thanks in advance
I'm not sure about the 3.0, but on the 3.4, there is a drain on the block on the passenger side. If that was passing, it would be leaking near (slightly ahead of) where the AC drain is. On mine, there is a bolt right beside a small metal tube coming out of the side of the engine (gotta look behind the flaps in the passenger side wheel well to see it). To drain the block, you loosen the bolt, and the fluid drains out through the tubing. Maybe grasping at straws here, but might be worth a look.
There's a couple of heater bypass hoses back there that can start to leak. Really hard to see, but back there, behind the plenum and in front of the firewall. Also, the casting plugs (x5 - 3 on the right bank, 2 on the left) can get corroded. This sounds more likely for your problem...looks like it's coming from the transmission mount. I just put some Stop Leak (eeekk) through it...no problem. I'll replace them when I do the clutch.
THe J-tube was the culprit. Thanks for the help. It had pin hole in it and was spraying the fire wall. It had to really rupture before I saw it. I jsut used fuel line and hose clamps, so far so good.
this j tube of which you speak
Is that the little bitty one that is so far down that you have to pull the plenum to change it?
If so, how hard was it to get off? I have all the nuts loosened but I want to be in 'n out in the same day. Doable?
James
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 02:03 PM
09-04-2015 10:27 AM
crashburnoveride
07-10-2015 07:39 AM
