Old 04-07-2016, 01:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Brake Guides
Print Wikipost
parking brake
Old 04-29-2008 | 09:08 PM
cosmo's Avatar
parking brake
Anyone ever have the parking brake warning light stay on in their Tacoma?
I can push the parking brake lever in while driving and it briefly turns off, then comes back on again.
Is there any way to adjust the linkage or lever so this does not occur?
It's not really a huge issue, but it sometimes gets annoying.
Old 04-29-2008 | 10:33 PM
warriors_03's Avatar
This sounds like its low brake fluid in the master cylinder not a linkage adjustment.
Old 04-29-2008 | 10:39 PM
NwRunner's Avatar
I had the same problem.
Go buy some brake fluid and fill your resivoir all the way to the tippy top, problem solved.
Old 04-29-2008 | 11:04 PM
DeathCougar's Avatar
Please do not just "fill it up" and forget about it.
Find the problem first. There is a reason the brake fluid is low in the first place, be it from leaking, worn brakes, etc etc.
Find/fix the problem first, THEN fill the reservoir.
Old 04-30-2008 | 08:10 AM
x2 on that one...
Old 04-30-2008 | 09:13 AM
NwRunner's Avatar
instead of tearing into the car to find a possible problem as deathcougar suggested, fill your resivoir and watch the level. If it stays the same you are fine, as with my case. But if it drops again, then you should look into fixing some sort of brake problem.
jashoeuh
11-26-2017 08:01 AM
skoob
10-15-2015 04:23 PM
romex1
08-10-2015 07:21 PM
terminator
07-27-2015 08:13 PM
CanRunner
07-20-2015 02:29 PM
