P0773 - Transmission Solenoid SL
Hi,
'99 4Runner, 3.4, 4x4 automatic, 233k miles.
4Runner runs well, and has for the last year that i've owned it. Everything's been going along fine.
Starting about 2 months ago, as soon as i just hit a steady flat cruise (55-60mph), i would get a slight/short "shudder", and my rpm's would drop ~300-500rpm. This drop/shudder wasn't consistent, and i thought it was a random misfire. Without having a CEL illuminated, I changed the plugs and wires. it made no difference.
about 2 weeks later, I popped a P0773 code, which is the lockup solenoid in the transmission.
The fluid wasn't dirty-dirty, but it wasn't a nice bright pink. I dropped the pan, tested the solenoid, and it checked out with the correct ohms per the FSM (~13ohms, iirc, and it's supposed to be between 11-15). i also put 12v to it and heard it make a soft click. It seems like it passed both checks per the FSM. there didn't seem to be an abnormal amount of junk in the pan, and there wasn't a ton of stuff stuck to the magnets.
i installed a new filter, refilled, and it drove great for about a week, then the issue came back along with the CEL (p0773 again). i flushed the fluid yesterday to make sure everything was squeaky-clean, and took it for a test drive. intermittent shuddering is still there. reset the CEL, and it comes back about 20-30 miles later.
am i screwed? should i try to replace the lockup solenoid even though it spec'd out ok? time for a rebuild?
i'm not having any issues with the transmission slipping at all, and have never had an issues with strawberry milkshake or anything like that.
4x4tacoma
7
03-30-2016 07:36 AM
