oxygen sensor / Check engine question
Old 07-07-2005 | 10:50 AM
dgold's Avatar
Can anyone tell me exactly how many oxy sensors are on a 1999 4Runner w/ Calif emissions?
If I get a P0420 code from the computer, which ones do I replace?
Any help would be most appreciated.
Thanks,
David
Old 07-07-2005 | 11:32 AM
94x4's Avatar
Guest
Sorry that I can't tell you dgold, but you should be able to "Search" that bit of info here.
Old 07-07-2005 | 11:46 AM
MTL_4runner's Avatar
Some reading for you:
https://www.yotatech.com/search.php?searchid=905052
Long story short, could be the O2 sensor or the catalytic converter causing the code.
Old 07-07-2005 | 11:53 AM
4RUNR's Avatar
Guest
MTL_4runner, btw, what voltage are you reading through Auterra for the 1st O2 sensor while idling?
God's Bounty Hunter
07-08-2015 01:54 PM
Alex Bessinger
06-28-2015 11:05 AM
94hiluxZE
06-22-2015 11:42 AM
Mutinebullfrog
06-18-2015 02:36 PM
