optimum shifting points or 22re...
Originally Posted by Five1Nine8Eight
If anyone is still interested.. I took my GPS to school today and on the way I found that my I am 10mph off. I have L235.75x15 BFG A/T, I measured them and they are 28" tall.
On the speedometer it says 20mph and the GPS says 29.8, and at 50mph in the truck the GPS read 60-61. It was hard to keep the speed consistant because it was really windy.
BTW, I have a 1994 2WD P/U 22RE.
I also started shifting at 3500-4000 today to try it out, I didn't know that lil engine had the power!
I have a tach on my truck and rarely use it (although I'm always right around 3000 rpm when i ˟˟˟˟). Listen to the engine. If you've driven enough stick shifts, you should know when to shift just by the sound.
sounds is always the best way to go because guages are not always accurate..unless of course you like to listen to loud music while ur driving ..haha since i got my new clutch ive been screwing up all the time because im so used to where it used to catch and i cant hear the engine or feel it because of my sub..lol i have to go back to driving with no music till i get a feel for the new clutch
#27
Originally Posted by Glenn
Your speedometer is off so much because your tire size is way larger than stock. My old 2wd came with 205/75-14 tires.
#28
Thats what I figured. Im going to get 31" tires next time around. Is it going to be off even more, like 13-14mph? Is there any way to correct the the speedometer?
#29
You can get a simple tach for about $30 at almost any auto parts store, like this one . They are real easy to install, one ground, one for a light, and one to read the rpms. There are several places you can tap into but There is an extra connection in a terminal you can plug it right into on your truck. Cant recall which one at the momemnt, but someone else will.
#30
Yes, it will be off by even more. You might be able to fix this with an adapter from Tacoma Speedometer & Instrument. I corrected my speedometer with one of their adapters, however your truck may not have a mechanical speedometer cable like mine. It might have an electronic connection.
this is for his 85 so its definatly mechanical.
I have had my speedo cable disconnected for a while because it was squeeking alot, when I replace it I will have to get one of those adaptors for sure. Mind me asking howmuch $$$ becuase it dosent say on their site.
#31
Originally Posted by phorunninduke
I dunno, for me it was really hard to get used to it. Comming from small block engines, the sound of a 4cyl getting higher rpms sounds soo wrong.
My owner's manual says the following:
2nd 15mph
3rd 25mph
4th 40mph
5th 45mph
2nd 15mph
3rd 25mph
4th 40mph
5th 45mph
#32
v_man
07-23-2015 05:01 PM
crashburnoveride
07-10-2015 07:39 AM
