Opinions on batteries - Optima Die Hard
The optima 34R sucks really bad, im glad i got it as a gift. For the last few days i noticed my 3.4L cranking very slow although it would start. Decided to take her to Auto Zone to check the voltage, everything was fine but the cranking amps were only 300....pretty sad for a 1000 amp battery. I went to Sears and picked up a Die Hard Platinum, same type of design with a few hundred less cranking amps but a full 4 year warrenty. Oh yea i had the 34R for only 2.5 years.
sorry to hear your bad experience w/ your optima. i dont know if the 34R is a redtop, or has the reverse terminals, and im too lazy to look into it, but my yellowtop has been going strong w/ tons of total drains, and a big stereo system for over 5 years, and i barely crank it for half a second, and my truck starts right up.
I hate my Optima red top. Complete garbage. I've only had it for two years and it's already giving me trouble. The first time you run it a little low, it will never be the same.
never had an optima, but i've bought batteries from Advanced Auto and had good luck and a great replacement warranty as well. now Die Hard on the other hand, bad luck with them and the local Sears store has found ways to void the warranty on both of the batteries i bought from them. will never buy there again. my advice, don't say anything to Sears when you bring in a dead battery or they will twist your words and void the warranty. in my experience.
I never used a 34R in my truck. I only went through 3 regular 34 red tops from '91 through '06, and the last one is now in my Volvo, since I put a yellow top in the truck. The regular 34 fit fine, turned around. Battery cables were long enough.
Out of all of the red tops I've had in all of my vehicles, I've only had 2 crap out early on me, and both of those were because the vehicles sat unused for extended periods of time (one month or longer in winter up here). I usually get about 7 years out of each of them, so I have to say that I have been a satisfied customer with them.
another issue with the Optima is that i guess because they are a gel cell, they take forever to charge. we have seen cases where someone jumps the Optima and then lets the vehicle charge the battery. They take so long to recharge that a lot of the time the alternators burn out trying to charge it. So if you run one low put it on a long slow charge.
no side posts. but i've been happy with my DHP group 35.
i bought one from a fellow member as a back up, he had the battery sitting in his garage in colorado for about 4-5 month, after i bought it, i had it sit in my garage for 4 months till mid march. i put it in and started right up with no hesitation after the whole cold winter not been charged. needless to say i'm sold on it.
kirkrunner
07-27-2015 08:59 PM
v_man
07-23-2015 05:01 PM
skoti89
07-08-2015 01:05 AM
