OME 881 / 906 Setup
My understanding is that if you pair the OME springs with the OME (comfort) shocks, it will ride comparably to stock (probably better). I have OME springs with stock shocks, and it's a little stiff for my liking. Stock springs with OME shocks would probably give you a spongy ride (just for comparison). If anyone knows better, please correct me.
Keep in mind that moving up to 265/75 changes your speedo's accuracy slightly as well. Theoretically with 265/75, when your speedo shows 65mph, you're actual speed is likely 66-67mph. So essentially your actual mileage will be somewhat more than what your speedo reflects.
Nine years of science in college has to come in handy somewhere.
[hijack]
Sorry about the double post, and Especially sorry about the flagrant thread hijack, but I just ran across this tire size calculator - probably the best I've seen. http://www.rims-n-tires.com/rt_specs.jsp
Total circumference for a 265/70/16 (notwithstanding the differences in tread depth and casing specs from tire to tire) is 96.2", whereas the circumference for a 265/75/16 is 99.4", making the 75 profile 3.3% greater than the 70. If your speedo is set to the 265/70/16 tire, when it reads 65mph, you will actually be traveling 67.15mph. 75mph translates to 77.48mph.
I thought the difference was more like 5%, but that was just a guess. My speedo is off regardless, so I just put it at or below the speed limit, and I'm usually speeding anyway.
again, 4biker= (and not even the best nerd )
[/hijack]
[/hijack]
#25
Here's another tire size calculator that tell you the speedo impact as well as the different dimensions.
http://www.1010tires.com/TireSizeCal...?action=submit
kawazx636
10-06-2021 04:03 PM
WTB[PacNorWest]: Old Man Emu Torison Bars
A2theK
10-14-2015 08:10 AM
4runnerFireman
09-29-2015 07:24 AM
