Oil in spark plug cylinder
Old 01-19-2004 | 09:09 PM
trangk's Avatar
Question Oil in spark plug cylinder
Went to do a compression test today and when I was removing the spark plug boots, #4 cylinder was covered in oil. Stuck the plug socket in and it was drenched, although it didn't appear to be any oil on the electrode side. What could be the cause of this? Bad valve cover gasket (namely the spark plug seals) or piston rings/ringlands?
I hope it's the valve cover gasket and not rings I have a catch can sitting between the PCV and the intake manifold, and there hasn't been any excessive blowby. The compression test was 190 across all four cylinders (I have the 2.7L) so I'm leaning more towards v/c gasket than rings, but anyone have any other opinions?
Old 01-19-2004 | 09:20 PM
Nam's Avatar
Nam
Re: Oil in spark plug cylinder
it's definitely the valve cover's gromet (sp) or the gasket. Yeah 2.7L is very easy to replace that and it doesn't cost much!
Good luck,
Nam
Eggslinger
06-08-2019 04:32 PM
09-04-2015 10:27 AM
cars-guy
07-11-2015 08:51 PM
smiley52
07-11-2015 06:16 AM
88runnergomas
07-09-2015 02:12 PM
