oil plug gasket
Re: oil plug gasket
Originally posted by BigJohn
Can i just use the old gasket on the plug
I have reused them too although you are not supposed to.
Just be very careful that there are no leaks after the change.
Take another peek in a day just to be doubly sure.
I re-used one last year on the rear diff. It leaked very slowly all year and there would be drops of lube on the tailgate and back glass after highway driving. I changed it yesterday and it was a pint low. I got 4 new gaskets to do both diffs and tranny/transfer. Tranny and transfer take a different gaskes according to the Dealer parts counter. At first thay wanted over $8 for the 4. I mentioned TLCA and they came down to $4.13.
I think one cent worth of black RTV sealant would work just as well as that $2.25 gasket. I just felt like visiting the dealer for once. Maybe next year i'll see if NAPA has anything that will work.
I won't try to re-use them again for drains. For fill plugs, I don't have a problem with re-using them a couple of times.
The diffs don't really have much fluid so be extra careful there are no leaks.
I don't suggest using any RTV because it can enter the interior of what you are trying to seal and possibly fill passages which should remain open. If you don't want to reuse the old one then buy a new gasket.
09-04-2015 09:27 AM
