Oil leak btw Trans and Case
Has anyone experienced a gear oil leak between the Manual transmission and transfer case?
Mine is starting to drip after 120K miles. Is this a DIY or shop job?
uberhahn
uberhahn
I would do it myself... Its pretty simple, just pop off the t-case and replace the output shaft seal. It is alot easier if you have the correct tool to pull out the seal than using a screwdriver!
