Oil Filter question.??
![Question](https://www.yotatech.com/forums/images/icons/icon5.gif)
Hi all, recently bought a 99 4 runner & trying to change the oil filter. Can someone tell me how to locate it & the best way to get to it.? Thanks.
p.s. This forum has been a great help so far.!!
![Thumbs up](https://www.yotatech.com/forums/images/icons/icon14.gif)
Originally Posted by Bob_98SR5
radarski,
welcome to the forum![Smilie](https://www.yotatech.com/forums/images/smilies/smile.gif)
check the tech section. there's a write up addressing this very issue. in the maintenance section.
bob
bob
Bit of a pain & kinda disappointing for a Toyota. Thanks again.
You don't HAVE to remove the skidplate, you can reach up through the fenderwell and get to the filter. Downside is oil all over your skidplate. It kinda builds up a gunky mess over time. Maybe if you take it off every 3rd or 4th change and chean the skidplate, it'd be alright.
I don't take the skid plate off mine or my wifes Runners. All thats needed is to reach through the wheel well after removing one plastic snap from the rubber flap. There is no need for a filter wrench either. The filter should not be more than hand tight. Turn half to 3/4 a turn after the filter seats. You may need a filter wrench and extension the first time but after that it's easy. I spray degreaser into the area that oil leaks after an oil change.
That's what I do too. But for some reason when I switched to the Toyota filter it was a major PITA to get off, and I never tighten it more that a 3/4 past hand tight. ![dunno](https://www.yotatech.com/forums/images/smilies/dunno.gif)
As for oil on the skidplate, I just deal with it. If I ever get around to banging that dent I got in Big Bend out of the skidplate, I will clean it off while I'm at it....
jasonty
41
12-23-2018 01:00 PM
