Offroading with a 5 Speed
I just bought a 4x4 5 speed 99 4runner, and i would like to do some offroading. Maybe a lift and bigger tires in the futrue.
Would a manual be a problem when offroading?
The only time you might have problems with a manual is if you are doing slow-speed rock crawling or when mudding.
The slow speed stuff can burn up a clutch in a hurry, but using low-range does help.
For mudding, just make sure you are in the right gear before you get in the mud, that or dont take your foot off the gas when you shift. If you take your foot off the gas to shift while in mud, there is a good chance that you will get stuck.
Tip:
Use the clutch as little as possible. A lot of people will get overzelous on hitting the clutch all the time and then stuff breaks. As long as you learn to do it right the first time, you are set.
Originally Posted by garrett1478
put it in 4L and its a piece of cake. you'll be surprised how slow you can go without stalling.
You know, I don't think I've actually done any serious wheelin' in a auto. I guess I can't really make a decision on what I like better. I really want to get my dad to go out with his FJ80. It has a 2nd gear start mode, so I could use low range and push that button when I didn't want to use first gear. I think that gives alot more control over the gears. Wheeling in an automatic I think is tougher because it can shift when you don't want it to if you arent careful or are in the wrong gear.
You should be thinking NEVER use the clutch. Of course, this is a slight overexaggeration, but seriously, it needs to be the exception - like ONLY to shift gears.
I have found that 4Low +2nd/3rd works really nice. It's low enough that you can start in it, and gives enough speed to have some momentum to make up for no lockers.
I like manual because there seems to be a tighter "connection" between my right foot and the wheels (although there are times on really steep stuff I wish it was Auto!)
Get out there and give it a try!
Like everyone else said 4LO will be your friend. Running in high range will make you ride the clutch more where as low range you can let it all the way out and just crawl. Manual is the only thing that I have been off road in.
I agree, a manual is the way to go.
I have driven both, and find an auto much less challenging.
I think that the best way to learn has been stated above as has clutch usage. Folks here know what they are talking about.
Using the parking brake as a 'hill holder' when starting on the steep stuff really helps alot. You don't feel the need to drop the clutch in order to get moving forward before you start flying back down the hill.
Going down a steep trail is also easier with a manual because you can just put it in granny low and let the trans hold the speed down as you decend. With an auto, you tend to need to brake more which can cause problems if you start skidding.
The clutch is in or out.
I wheel an auto with a crawler.
Wheeling with people who have sticks and no crawler is a lot more entertaining than watching a guy with an auto walk through.
If you wheel a stick much, get a crawler. It will make life easier.
My auto, with 5.29's an stock low range goes down hills plenty slow.
Thanks for all the replys, I have one question. Could you expain the 'clutch start-cancel' button for me?
