OEM Lift Help Me with Pics
barely used, $85 shipped from CO to TN, from ravencr
it was listed here for sale for over 2 years. at that price, i couldn't pass it up. i used to have the TRD bags on another runner i used to own and loved the feel and adjustability, so when these came across my lap for that price (the cost of just the bags when new basically) i had to jump on it.
Installation Details
No offense to anyone but I don't think the "all Toyota" lift looks very good unless you plan to run 33s. If you want to run the Toyota setup up front (2" of lift), then instead of running 3-3.5" LC coils consider using the OME 906 2" lift coil that was designed for the 4Runner. Then you'll have an even lift that shouldn't look goofy with 265s.
Ken
Ken
Ken
Ken
Originally Posted by bamachem
wow. too much lift in the rear.
i have a solution for ya at the end of this month, i'm swapping all my stuff out yet again. the fronts that i'm running now are taken, but the rear setup is up for grabs. i have 2.5" downey lift springs that have been used, so now they're more like 2.0-2.25" lift springs on a stock runner. with my HEAVY rear bumper and tire carrier, they're down to about 1.75" for me.
if you want them, i'd let them go for about $140 shipped (they're $290 + shipping new). also, they're progressive rate, so they match the ride quality of the fronts nicely.
i also have the used OME N86 shocks up for grabs if anyone wants them... $110 shipped gets 'em.
You have PM
Thanx
#25
i am probobly going to just leave it as it is, the ride is awesome. not too stiff, but planted feeling. and in the future, ill upgrade to 285's unless i can sell the 265's or whatever. in person it doesnt look too bad, and i dont have to worry at all about rubbing at all, it is close in the back when stuffed though, front did rub and I had to remove the limited flair peice on teh bumper, but it still barely touches the rear inner part of the fender occasionally.
#26
Kyle do you have any now settled Pics with maybe a 100 lbs of weight in the back? I'm always carrying about 100 lbs of tools with me for work.
Thanx for you help guys hopefully before May I can make a decision.
#28
yeah, i just put the front spacers on too, so ill try and get some pictures today or tomorrow, it looks more evened out now. i know the car still sits back high, but i like that look, more of an aussie style I guess, i know in Cali they like the prerunner look with the back lower, so it is all personal preference i guess.
bamachem, you ran the trd shocks/springs up front right? did you have squeeking/clanking problems? I cannot find where they are coming from sounds like the swaybar is loose, but i tightened it as much as it would go, any ideas on where i should look?
#30
Both pics over 3/4 full of gass if that makes a difference.
lift just installed, less than 50 miles ago, no top out spacer:
about 400 miles and top out spacer installed (i have a case of 36 bottles of water in the back as well, maybe 30 lbs at the most)
#31
#32
#33
kyle,
one or both of the top out spacers?
since i have a 2wd i'm considering buying the daystar front spacer from wheelers cause im just a fan of the level look....but i dont know if theirs is actually 1.25" or 1" bc daystars website does not list a 1.25" front spacer...but hell for like less than 85 bucks i say its worth it to me
lookin good :bounce2:
Mark
Mark
#34
only one of the spacers, cv angles would be too great on droop with more. and they are very steep when at full droop.
the spacer is the one that sonoran steel supplied, i believe that bamachem manufactures them, it looked to be about 5/8th inch thick.
#35
I do clearly state you will get 2" front and 3.5" rear. That is 1.5" higher in the rear.
Why higher in the rear? The ONLY way to make the 80 shocks work. If you install the 80 rear coils and rear shocks WITHOUT all the Sonoran Steel "fixes". You WILL destroy the shocks, rear sway bar, sway bar links and lower link bushings the first time out. How do I know? I have bought those replacement parts many many times. This lift was a 5 year ordeal to get right.
If you just order the Toyota parts and don't install any of the fixes, all I can say is you are on your own. I can't fix what I was never given the chance to fix. Some of the items are only available in the full lift kit. Please do not ask me to sell you those items individually, as they are only available with the full kit.
Unlike other lift kits, the main emphasis of this lift is pure off road performance. If the rear needs to be 1.5” higher to gain a huge amount of added rear travel (3.5” more). That is the way it needs to be.
#36
no have not had a chance to try and tighten the shock bolt.
and, yes, the kit is complete, no problems whatsoever when i installed, everything went on very easily and it looks OEM (obviously) im super happy with the height now that teh spacers are in, and i can tell you that the rear flexes like mad. i was stunned that it could do what it did.
also it was alot easier and cheaper to order everything from Steve at one time, vs trying to piece it together, and he is super helpful in the 99 million dumb questions i asked him. he has gone beyond what most other venders have ever done for me.
#39
I just put this OEM lift from Steve.
My 97 4Runner even rides better then stock!! Those LC coils could even give you up too 4" of lift!!
Here's a couple shots of my Truck running on 305/70 MTR's>>
#40
The rear coils are brand new and will go down over time to 3.5".
The pics above are without the front top out spacers, if you add them, it's sits pretty level, but if sitting level is impotant to you, this is NOT your lift.
That would be System 7. Which will not perform as well off-road, but sits very level.
