OEM Filter for A340F tranny - Part Number?
Old 11-30-2005 | 04:12 AM
KZN185W's Avatar
Hi,
Does anyone have the oem part number of the atf filter used in the A340F tranny of the 3rd gen 4Runner?
Appreciate your help. Thanks.
Old 11-30-2005 | 06:00 AM
MTL_4runner's Avatar
Just clean it, no need to replace since it is a fine metal mesh screen.
Old 12-01-2005 | 03:42 AM
KZN185W's Avatar
Jamie,
I thought that whenever the tranny is flushed, the filter needs to be replaced. That's also what the Amsoil site recommends.
Thanks.
Old 12-01-2005 | 09:46 AM
Originally Posted by RoySharif
Jamie,
Thanks.
Roy, on most vehicles you'd be absoultely correct. The A340 is a bit different than other tranny designs. When you remove the filter, you will see that it is not made of paper, instead it is a very fine metal mesh screen. If you were doing a flush or even just pulling the pan on the average vehicle with a fiber/paper filter then you should replace it for sure, but the metal screen design is such that it can be reused many times by just cleaning the debris from the filter. I use brake cleaner, but it needs to be throughly dry before you install it again. Most dealers don't even stock the part because the mechanics will nearly always clean the screen instead of replacing it. If the screen is torn or physically damaged, then it should be replaced.
Old 12-02-2005 | 03:13 AM
KZN185W's Avatar
Jamie,
Thanks for the clarification. Yes, the local Toyota dealers here don't stock the filter.
Thanks again.
bigjstang
08-25-2021 01:41 AM
mskalmus
05-28-2017 08:51 AM
msane99
07-11-2015 09:08 PM
cyclist231
07-07-2015 01:56 PM
MTLroadierunner
07-06-2015 01:17 PM
