Odd sound during acceleration... Clutch?
A kind of screech sound (almost like a tire squeal but not) sometimes briefly happens when I'm accellerating from 1st to 2nd as I release the clutch in 2nd and im underpowered while giving alot of gas; hopefully that makes sense.
For example:
I'm on a hill stopped facing up the hill. I accelerate, shift into second and begin to let the clutch out while applying increasingly more gas (to make up for the pause in shifting and the increasing grade) and if i hit the gas too much while the clutch is just about to engage there will be a long whiney squeal until a couple seconds after the clutch fully engages. It has only done it like 3 times, but it concerns me.
Any ideas?
For example:
Any ideas?
Same here
I get the exact same behavior. My rig is also chirping like a cricket at idle with the clutch out. I'm told this is the throwout bearing squeaking against the fingers of the pressure plate, and that it is annoying but not a problem. I'm thinking the squeal under acceleration may be from the same source.
T/O Bearing
It probably is most likely your T/O bearing and if you're going to replace it and go through the trouble of replacing it, you might think about a new clutch and pressure plate while you're in there.
I had a a screech/squeaking sound everytime I let out the clutch and determined that I needed an entire clutch job. Took it to the tranny shop and they diagnosed it as a bad u joint. Boy was I happy to hear that!! It fixed the problem. Might be worth looking into the u joint(s) before an expensive (if you take it to a shop), pain in the ass (if you do it yourself), clutch job.
he's gone
7
12-03-2019 07:08 AM
