View Poll Results: What grade of octane do you use most frequently?
87
110
51.16%
89
41
19.07%
91
34
15.81%
93
30
13.95%
Voters: 215. You may not vote on this poll
octane rating?
#41
Originally posted by mpulver
Yeup. Yeup. Yeup. Nope.
Yes I really am running the sucky 87 octane winter gas. Yes I did the ISR mod and Yes I was part of Dr. Z's "beta test" group to plug the FPR. And nope, no pinging.
But... I'm also running the ECT mod which is letting me run richer, (and also advances the timing a bit), so that might have something to do with it.
#42
Originally posted by vtruong1
COOL!! Thanks for the info. Will get on that mod asap. What is the ECT mod?? Got any info or writeup on it?
The ECT mod is documented here:
https://www.yotatech.com/~corey/tech/dr_z_ect/dr_z.htm
#46
I run mid-grade 89. If I run 87 I get some pinging under moderate throttle. It's been this way since new. I try to run Chevron whenever I can because of the additive package.
Ray
Ray
#47
87, and I avoid ARCO like the plague. I use either unbranded, 76, or Chevron. I prefer unbranded. It doesn't have any additives, so you are getting the purest gasoline. If there isn't any unbranded, then I go with the other two. Their additives seem to be the best. I avoid ARCO because of what they put in their gas. Ethanol, and lots of other "filler" that isn't good for your engine. When I had my older truck I could really tell the difference. Just because I can't tell the difference with my Toy doesn't mean that there isn't any. I figure I'm taking preventative maintainance by avoiding ARCO.
#48
91 is the highest we have here, to avoid pinging I am experimenting with Toluene, so far so good, I have run 2 tanks though and it runs better than ever. My mileage did drop though.
1 gal of Toluene (114) with 14 gal of (91) = about 92.5
#49
I use 87. 4Runner engines are designed to use 87 octane. Only higher compression engines use higher octane fuel to stop it from prematurely firing. Higher octane is harder to 'combust', so it is useful in high compression engines only. If you use it in 4Runners, you will notice a loss in power and fuel economy because the compression ratio is relatively low compared cars that recomment high octane fuel (4runner is 9.8 while some cars go up to 11 or more). Putting high octane fuel in the 4Runner means that the fuel may not fully combust properly which would leave deposits in the cylinder. If your 4Runner pings while using 87, then putting in a higher octane gas would only be a temporary solution.....it really means that something is wrong with the engine. This info that i'm posting is for non-SCed runners.
SC'ed runners 'push' more fuel mixture into the cylinder so that there are higher pressures in the cylinder. Higher octane fuel is probably recommended for them, but I am not sure.
#51
I use 87 and it seem to work fine for me.
Its been a while since I've used the mid-grade stuff. Perhaps I'll try some of that stuff next fuel stop and maybe get even better mileage from what I'm getting now
I've never used the PREMIUM stuff, wonder how that works, if there is any difference.
#52
#53
Toluene
Originally posted by keisur
Me being chemically brain-dead, what does Toluene(114) do for the system?
EDIT: Higher octane fuel is only necessary in higher performance engines that need a higher air to fuel ratio to perform at peak efficiency and approaching the unobtainable complete combustion level. It does not matter how much more octane you add to the fuel mixture if it is not in proper ratio to the air it still will not combust properly.
#55
Re: Toluene
Originally posted by waskillywabbit
It is already found in crude oil products. You can do a Google and get.
#56
Re: Re: Toluene
screw it, I'm to lazy to search and read. hehe. oh, I DO notice when I use 87 I knock and when I use 92 or 93 it doesn't knock.
#57
Re: Re: Re: Toluene
The knocking could be due to: differences in quality of gasoline, differences in brands of gasoline, it's all in your head - it could be any number of things as to why that happens. I still think paying for higher octane without a modified high-performance engine that really needs it is horse puckey. Thermochemisty dude, thermochemistry!
#58
Re: Re: Re: Re: Toluene
didn't take thermochemistry, wasn't required, you know that! Mine is modified for high performance, I did the intake silencer mod and can smoke any viper or corvette as long as their engine isn't on!
#59
Re: Re: Re: Re: Re: Toluene
Aren't you an ME? Basic thermochemistry is taught in Thermodynamics I and II.
I remember how to make a calorimeter though, hehe, a styrofoam coffee cup and a lid.
#60
