Is this noise normal?
I've owned my 2002 4Runner for about 2 months now. Had the timing belt, drive belts, idler bearings, spark plugs and other stuff replaced.
Since I've owned it I've noticed a sound at idle. It can only be described as a rapid and continuous "pop pop pop". About the same rate as rpm. Put your lips together and make a popping sound as fast as you can and it's about there. It's not loud or obnoxious. But it's odd to me and a bit annoying. It seems louder when the weather is cold, but is there when the engine warms up and weather is warmer.
Is this normal? Is it a sign of impending doom or the coming of the anti-Christ?
Any insight is appreciated.
MadCityRich
'02 Limited
stock as stock can be
MadCityRich
'02 Limited
