new yota owner with heat problems
Hey all, just got a 98 4runner, first yota ever for me. I was a jeep guy but thought I would give toyotas a shot. Well my heater blows warm, not very warm, not really evan enough to keep me or my kid comfortable. The engine gauge shows the motor heats up pretty quick, just below the middle of half way between hot and cold.
Im just wondering if you guys could point me in the right direction, to start checking, I NEED HEAT!!. also is there anywhere I can get exploded views of the cable system back behind the dash or if its vacuum. The vent wont goto defrost or floor or, well you get the idea.
Thanks and I hope this is in the right section.
Here is the manual for a 02' 4Runner.....it's the closest your going to get for free....
http://www.ncttora.com/fsm/1996/SIL/index.html
I would start by checking the coolant level.... is the overflow container up to the normal level?
To remove an air bubble from the system, turn heater valve to hot (rear heater also, if equipped), take off rad cap and heat up engine until thermostat opens......add coolant as needed. (make sure it's the same fluid type, OEM fluid is pink)
I would also verify that the when you are selecting between hot and cold the heater valve on the pass side firewall is opening and closing.....
Beyond that, a clogged heater core is about the only other thing that I can think of that would be causing your issue.
THanks going to try it out today
Well I don't own anything newer than 2nd generation, but the heating control is probably still the same. First question: does it have rear heat and does it work? The rear heater on my 2nd gen only controls coolant flow to regulate temp. The front heater regulates both coolant flow(eng comparent coolant valve on firewall) and mixes airflow. On my 1st and 2nd gen vehicles, this is done with a push/pull cable that runs down near the passenger floor area. This cable works an air mixing valve/damper.
If the rear heater dosn't blow hot air, it is probably a coolamt flow issue. I have seen the problem you describe on a 4runner and a ford, and both were the air mix control cable where it attaches to the mix assembly. Specifically it was the metal clip that secures the end of the control cable sheath.
Good luck.
Good luck.
Location: raleigh, nc for school chapel hill, nc for home
I had a similar problem (the heat would only be warm and never get hot), and the thermostat had broken.
It's fairly easy to replace and located on the passenger side under the dash.
Turned out it was simply the cable to the door had came loose??? The door would not close all the way. Lucky and ez fix. Now if I can just get my selector switch to work. to go from vent to defrost.
Good luck.
Thanks for the input, I fixed the heater on my 98 4Runner today by reattaching the cable to the clip.
On the passenger side below the dash, but in reach of your feet, is the cable which determines hot or cold. This cable is near enough the floor that you could kick it loose or if you frequently carry pets, they could dislodge it.
Turning the dial moves the cable which moves a spider assembly behind the center console. If you look with a flashlight, you can easily see it.
On mine, the cable had come out of the clip and was moving freely.
It took some trial and error to get the cable in the clip correctly, but once connected the spider assembly fully moved in both directions. Now the heat through the vents is as good as the rear floor heat.
I attached a picture of the clip. Have fun!!
the1998sr5
15
07-14-2020 08:35 PM
rushw
07-18-2015 01:46 PM
