New Tire Squealed for no reason
This is kinda odd but maybe someone has an answer so I'll go ahead and post.
My buddy and I put on some brand new BFG A/T K/O's 265/75/16 on my truck today. Well we were using a hunter machine with road force variance to balance the tires. All were good till we got to the last one and it required 7oz of weight on the outer rim even after we matched the tire's heavy spot to the rims lightest spot.
So we decided to use stick on weights in the inner rim. Although its not the best method to balance an offroad tire that size it still works. And it did, and the wheels look great without all those weights on them.
I took it out and drove it up to 85mph with no vibes.
Anyway I went over to his house and we hung out blah blah. Then I stopped by the car wash on the way home to get the blue protective crap off the wheel lettering.
So I leave the car wash and I'm almost home and I here tires squealing. Sounds like someone is about to hit me. It only lasted about 3 seconds. I look around and I'm the only person on the road for miles.
I didnt feel any viberation or anything out of the normal. I got home and checked the pressures and all were right on the money, well a little higher but the tires were hot, but the front two matched pressures and so did the rear.
What would cause one of my tires to suddenly squeal for no apparent reason? BTW I was driving straight at about 45 mph and there was nothing around so I know it was my truck. The road was also flat and well paved.
Yikes seems like I was rambling a bit. But I wanted to mention the car wash because I got all the grease that was on the tire from the factory off. When it squealed the tire was long dry.
Maybe I'm over reacting. Any thoughts?
Originally Posted by Localmotion
sorry no thoughts about the squeeling. from my personal experience, the sticky weights just come off if you wheel them. it may just be my retarded set, but they came off in about 6 months. BUMP FOR SQUEELING!
I guess I need to drive it around and feel it out. I beginning to second guess myself. I dunno if it was me or not, I really didnt see anyone around. But I cant imagine a single tire sqeeling for no reason and then to top it off me not being able to feel anything at all in the steering wheel or anything.
Other possible causes? A belt squealed, a seal somewhere squealed, CD accessing a track squealed, cassette sqealed, 8 track squealed, another one of those stupid radio commercials with realistic sound effects? (I hate those! Sirens, horns honking, tires screaching sounding real and making me look around in panic...)
From: Far western Kentucky (transplanted from central PA)
Was there any perceptual, momentary change in how the car was handling? When you say squeal, I'm assuming the wheel locked up or something. If the car didn't react, then what you heard was probably NOT a tire.
I've noticed when my alignment was off the tires would squeal on smooth concrete. If the toe or camber is off then it's possible to get squeal even when you're going straight, wet or dry. You may want to check your alignment especially since you got new tires.
I've been having problems keeping air pressure in one of my tires...it drops all the time and the sidewalls look fine so visually you can't tell...but the pressure drops down around 20lbs. When this happens......it squeals like crazy! Just for kicks...check the pressure!?
could be an out-of-spec tire.
i'd suggest taking a VERY close look at the one that required 7 oz. if it's THAT bad out of round and out of balance on a road force machine, it's possible that the bead is also bad and it might be slipping on the rim.
That happened to me once on a recently paven road, flat, perfect, nobody around...I turned around after checking the rig out and it turned out there was a huge spot of oil or grease or something on the ground, I assume what happened to me was that as I drove over it the right wheels accelerated and were slipping and then once it hit the pavement it squealed a little bit until the oil/grease residue was off. Never happened again...
Fink
Fink
Flying91
45
04-11-2024 05:39 PM
nickbeauregard
12
08-07-2015 07:04 AM
DrZero
18
07-25-2015 12:31 AM
