Old 04-21-2016, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
New Suspension Setup - TRD Front Lift for a 3rd Gen 4Runner!
Old 11-19-2006 | 06:49 AM
  #781
cujeeprs's Avatar
I am new to the site, and I love the info that is posted about th3 3rd Gen 4Runners. I have a 2002 Sport that I am considering lifting. I have some questions about rim size and offset. I saw in the thread a post about 265/75/16 being the largest tire size without rubbing. I am currently running a 275/70/16 Revo with only a 1" rear spacer for leveling, and there is no rubbing. I want to step up to the 285/75/16 BFG's with the stock Sport wheels. Is this possible? This is a daily driver that sees a lot of interstate driving. It is also used for occational hunting trips, but nothing extreme. Would the 285's rub the upper arm? I can handle the trimming of the firewall and plastic, if that is the problem. I had a set of 265's on a stock 1997 SR% 4Runner with no rubbing, but I realize that the 2002 sits lower from the factory. This is my first venture into lifting an IFS truck, my past experience is with my CJ-7 and '85 toy flatbed. Thanks for the help. Scott
Old 11-19-2006 | 09:16 AM
  #782
neliconcept's Avatar
cujeeprs, welcome to yotatech and you are in my neck of the woods,, best thing to do is search but ill try to answer your question.
with stock wheels they are 16x7, and 285 bfgs may or may not rub the upper a arms but the risk is you need to get some wheel spacers, get custom upper a arms or shaved a arms. Or you need some cheep (pro comp alloy comes to mind) 16x8 either 4.5 backspaced or 4 inch backspacing.
Old 11-19-2006 | 09:33 AM
  #783
ecchamberlin's Avatar
Andy
having the Blue Tokicos on for a little while now, what do you think of them? Have you wheeled them yet?
Old 11-19-2006 | 11:51 AM
  #784
bamachem's Avatar
haven't wheeled them yet. they're soft on the road - very VERY plush.
Old 11-20-2006 | 10:14 AM
  #785
jeffoto's Avatar
having read through this whole post, I'm grateful for all the research and testing that has been done.
I just bought my 2001 4Runner and have a line on a set of LC springs and have found a local pair of Tundra TRD front springs.
Just to clarify, and I know the answer, but you CANNOT use the Tundra shocks (front or back), is that correct? (I have to ask because I could get the complete Tundra setup for $120, assembled front springs/shocks and rear shocks - TRD Bilsteins.
Thanks,
Jeff, new Tucson 4Runner owner.
Old 11-22-2006 | 06:49 PM
  #786
bamachem's Avatar
you could use the fronts if you swapped out the top plates for the correct ones, but you don't want to - they're too stiff. you can't use the rears - different upper mount.
Old 11-22-2006 | 10:13 PM
  #787
jeffoto's Avatar
thanks Andy. The fronts I got but the shocks are Tokico, so this wasn't a TRD. The paint code on the springs are two red and two pink .. Any idea which side the red goes on, and which side the pink goes?
Thanks again,
Jeff
And do you think Tacoma stock Tokico would be alright? Any idea on shock length?
Sorry for all the questions, just didn't see this particular setup addressed.
Old 11-23-2006 | 05:25 AM
  #788
bamachem's Avatar
honestly, the tokico's for the tundra might be OK. you need to check the extended length. i've never seen that paint code on the coils though. are you SURE they're from a TRD tundra and not some type of tacoma?
Old 11-23-2006 | 07:32 AM
  #789
jeffoto's Avatar
I was told it was an 03 Tundra, 4wd. So, I'm not sure what they are from exactly. I'll compare them to my 4Runner setup and also get the numbers off the shocks. I may have wasted $75, but it was a great deal if I didn't waste it ...
Thanks,
Jeff
Old 11-23-2006 | 07:54 AM
  #790
bamachem's Avatar
well, i'm thinking that they're NON TRD since they're not a color combination that we've seen before. also, they could be 2WD, which are basically equivalent to stock runner coils - just a tad stiffer.
you really NEED the TRD coils to make this work the way it's supposed to. they're progressive rate, and are soft on the road. the NON-TRD coils are NOT progressive and have a constant spring rate for the entire travel of the coil.
do it right. get what you KNOW works - the TRD coils.
Old 11-25-2006 | 07:37 PM
  #791
jeffoto's Avatar
Ok, after a long trip to Hoover Toyota at Lunch, here's what I found...
For a 2004 4WD NON TRD Double Cab Limited, the coil springs were Orange/Green and Red/Red.
Hey Andy, after reading this thread for the third time, I found one of the color combos of my springs - Red/Red that you found above, the other one is two pink or light purple/lavender.
I also have the Tokico part number on the shocks: red/red spring has 030620B on the shock body, pink/pink has 030627A.
I have a friend with a Tundra double cab and will try to look at his setup next time I see him, but so far I've had no luck finding those part numbers on the web (no surprise since I'm sure it is a Toyota only spec).
Does anybody have any additional insight? (I'm guessing I have 4wd, non-TRD springs/shocks).
Old 01-04-2007 | 04:14 PM
  #792
AustinTaco's Avatar
I don't know if this will just add confusion, but while searching for a deal on used TRD Tundra coils, I found some interesting info. At Car-part.com, if you search for Tundra coils, a pop up comes up that will list about 20 different variations. On the bottom of the pop up it has lengths for the double cabs with one being measured at 369 mm and I think the shorter being 358. It also had a description of "w/US mkt" and "w/o US mkt" so I guess the US mkt might be different?
I also found that most yard will just use the first category as the default to put their part in, so it will still take some legwork and phone calls to get the right part. Buying new might just be worth it!
Old 01-06-2007 | 11:45 AM
  #793
AustinTaco's Avatar
Here's the list of coils from car-part.com. I am not sure what US mkt means, but there is a difference in length between the springs which might explain some slight difference in height between one setup and another.
Front, 4x2, 2 Dr, 6 cyl, w/o Bilstein shock opt Right
Front, 4x2, 2 Dr, 6 cyl, w/o Bilstein shock opt Left
Front, 4x2, 2 Dr, 6 cyl, w/Bilstein shock opt Right
Front, 4x2, 2 Dr, 6 cyl, w/Bilstein shock opt Left
Front, 4x2, 4 Dr, Double Cab, R., w/US mkt (352mm length)
Front, 4x2, 4 Dr, Double Cab, R., w/o US mkt; (344.5mm length)
Front, 4x2, 4 Dr, Double Cab, L., w/US mkt (355.5mm length)
Front, 4x2, 4 Dr, Double Cab, L., w/o US mkt; (348mm length)
Front, 4x4, 4 Dr, Double Cab, R., w/US mkt (363.5mm length)
Front, 4x4, 4 Dr, Double Cab, R., w/o US mkt; (356mm length)
Front, 4x4, 4 Dr, Double Cab, L., w/US mkt (369mm length)
Front, 4x4, 4 Dr, Double Cab, L., w/o US mkt; (360.5mm length)
Front, 4x2, 2 Dr, 8 cyl, w/o Dlx Right
Front, 4x2, 2 Dr, 8 cyl, w/o Dlx Left
Front, 4x2, 2 Dr, 8 cyl, w/Dlx Right
Front, 4x2, 2 Dr, 8 cyl, w/Dlx Left
Front, 4x4, 2 Dr Right
Front, 4x4, 2 Dr Left
Front, 4x4, 4 Dr, Access Cab, L., 356.5mm length Right
Front, 4x4, 4 Dr, Access Cab, L., 356.5mm length Left
Front, 4x4, 4 Dr, Access Cab, R., 351.5mm length Right
Front, 4x4, 4 Dr, Access Cab, R., 351.5mm length Left
Front, 4x4, 4 Dr, Access Cab, L., 363.5mm length Right
Front, 4x4, 4 Dr, Access Cab, L., 363.5mm length Left
Front, 4x4, 4 Dr, Access Cab, R., 358.5mm length Right
Front, 4x4, 4 Dr, Access Cab, R., 358.5mm length Left
Front, 4x2, 4 Dr, Access Cab, 6 cyl Right
Front, 4x2, 4 Dr, Access Cab, 6 cyl Left
Front, 4x2, 4 Dr, Access Cab, 8 cyl Right
Front, 4x2, 4 Dr, Access Cab, 8 cyl Left
Old 02-01-2007 | 07:12 AM
  #794
Mojo_Risin's Avatar
Reviving this thread yet again....
Jefoto - Did you ever proceed or find anything out about the Tundra shocks?
I'm looking for other shock uptions for the front besides the Tokico blue and the Tokico greens seem to be sold out.
thanks
John
Old 02-01-2007 | 07:38 AM
  #795
TRDatVT's Avatar
I have been doing the shock hunt as well and i posted what i found here. I will be trying something new and going with the Monroe Reflex shocks. The guys over at Monroe said that they are stiffer than stock and should be perfect for my application. Also as you can see from the info in the thread, they are not long enough to give us droop problems!:
https://www.yotatech.com/forums/f31/4runner-lift-shock-options-105747/
Old 04-29-2007 | 04:26 AM
  #796
cox380's Avatar
are the tundra struts any longer or extended compaired to the oem struts?
Old 05-14-2007 | 12:04 PM
  #797
Motayota's Avatar
Originally Posted by sschaefer3
No greens for a while. I can get you a big thick black one though. Great big lower heavy duty bushing, correct valving and length. Those are 40 bucks more for a pair than the greens and come from the Toyota Dealer.
Anybody know the part number for these Heavy Duty Black Tokico shocks?
Old 07-08-2010 | 09:39 PM
  #798
fenrisx's Avatar
Hate to beat a dead horse..
But it seems most people are using 4wd TRD Tundras with a top plate spacer? My head is literally hurting from trying to dig out info from all the threads! What about 2wd TRD Tundras? I'm looking for one to use without a spacer to pair with OME 906's in the rear.
I've got a set of Trekmasters to go with these, so would these not really be ideal for TRD Tundras? I'm looking for ride height similar, but not more than, an OME 881.
Old 07-09-2010 | 06:09 AM
  #799
Mojo_Risin's Avatar
I had the trekmasters - and blew one out just going over a whoop-dee-do a little fast - really never liked those shocks... on the other hand I switched to the Bilstien 5125 adjustable shocks from Sonoran Steel - which meant I didn't need the spacer anymore to add lift with my tundra coils- and these shock are awesome!!! I would recommend going with the Bilstien's vs trekmasters 100 times over.
Old 07-09-2010 | 07:28 AM
  #800
AustinTaco's Avatar
Is Steve selling the shocks separately now? The last time I looked into buying them, and its been awhile, he only sold them with his kits.
