Old 04-21-2016, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
New Suspension Setup - TRD Front Lift for a 3rd Gen 4Runner!
Old 12-07-2005 | 11:09 AM
  #721
bamachem's Avatar
are they 7-wrap coils?
you're going to be so boody-high... make sure to take some pics of your roadster-runner...
Old 12-07-2005 | 11:47 AM
  #722
ravencr's Avatar
Nope, solid 8 wrap coils, and we'll see how it sits hopefully tonight. I'm going to depress my air shocks down to 20 psi, measure the bumper height, then install the springs and measure it again. We'll see, because I've got all the extra weight of my tank and skid plate, plus the weight of my rear bumper back there. Hopefully it will be just right.
Chris
Old 12-07-2005 | 09:01 PM
  #723
RTdawgs's Avatar
Originally Posted by ravencr
Ryan, I know you're kidding, but good one!
Chris
Thanks, I'm funny sometimes.
Originally Posted by sschaefer3
You'll need an SAS to run dirt roads, just do it now.
Dirt roads? I wish. How about paved roads with potholes, thats more like it these days. Someone come steal my truck and actually use it.
Should I get 285 MTs or ATs? Will I rub?
Old 12-08-2005 | 02:30 PM
  #724
OneSpeed's Avatar
At the risk of getting flamed, I haven't found anything yet about using the Tundra TRD coils on stock 4Rnr struts. I'm a noob and have a 2001 bone stock SR5 4X4 on which I'm considering this lift option, based on all the info documented on this board. Not much offroad time, unfortunately; mostly highway miles with an occasional trip to the rocks and trails. Could I put the TRD coil on my existing strut (with no top spacer) - will it fit? Would this result in 1.5+" of lift with a close-to-stock on road ride?
For the rear, does anyone have experience with the OME906 spring? My truck is typically driven unloaded. The goal would be 1.5-2" in the back to match the front.
The thought for using this set up is that I could lift a little now, and if I wanted to invest more later (shocks) for heavier offroad use I would have springs I could re-use.
Comments on this?
Old 12-08-2005 | 02:36 PM
  #725
ravencr's Avatar
Comments on this?
My thought on the front is once you use a spring compressor, you'll never want to do it again. They're not the safest things in the world, and they take a little bit of time to do, so I'd recommend replacing the front shocks at the same time you do the springs. You won't regret it.
Chris
Old 12-08-2005 | 02:40 PM
  #726
sschaefer3's Avatar
Comments on this?
The 4Runner stock shocks are really short and as Banjo has stated, you only want to do it once. The shorter shocks will not only limit your travel but you really have to compress the heck out those coils to get them on there. Buy replacment shocks, get the Stock TRD Tacoma shocks and save yourself alot of grief.
Yes it probably could be done, but those shocks (stock 4Runner) are junk. They are only 20 bucks each new.
Tacoma TRD Tokico Shocks: 48510-A9160
Old 12-08-2005 | 04:42 PM
  #727
OneSpeed's Avatar
This sounds like good advice - thanks for the feedback. Does anyone have experience or thoughts on the OME906 for the rears? I see little about these springs; far more about the 89x. Thanks.
Old 12-13-2005 | 08:16 AM
  #728
bamachem's Avatar
Well, since this thread is compiled of my buildup basically, the following new parts are coming in today:
1) Lift Lips - to cover the body lift gaps
2) Tundra Front Coils
3) Tie Rod Boots
4) All-Pro Extended Rear Brake Line
5) H&H Speed & Machine - (2) 2 1/8" Urethane Bushings w/ 3/4" threaded studs for my new upper links
Chris
hijacker.
Old 01-18-2006 | 10:25 PM
  #729
namekim99's Avatar
If i was to go with the All Toyota OEM lift that was stated earlier, do i need to get new bump stops for the front and/or the rear? and the e-brake bracket and a longer brake line to adjust for the lift?
Old 01-19-2006 | 06:28 AM
  #730
sschaefer3's Avatar
Yes to all since the compressed and extended lengths of the LC shocks is longer. Bumpstops only the rear, yes on the brake line and e-brake bracket.
Old 01-19-2006 | 04:42 PM
  #731
namekim99's Avatar
Whats the height of the tundra coils by themselves.
Old 01-19-2006 | 04:46 PM
  #732
Localmotion's Avatar
im pretty sure that info is in this thread
Old 01-19-2006 | 04:59 PM
  #733
namekim99's Avatar
I was unable to find them, i think someone asked earlier but there was no answer given
Old 01-19-2006 | 05:02 PM
  #734
bamachem's Avatar
on a runner, 1.5" lift
on a tacoma, 2.0" lift
yes, there's THAT much weight difference between the two.
Old 01-19-2006 | 05:07 PM
  #735
namekim99's Avatar
thanks for the info, i also want to know the actual height from bottom to top
Old 01-19-2006 | 06:18 PM
  #736
Bob_98SR5's Avatar
name,
its in this thread. i saw it myself. please go back and read. and even if the answer wasnt here, the part numbers are. you could have had your answer by calling your local toy parts store in the same time you waited here for an answer
you know, you as well as the rest of us are really lucky that this thread exists. this is about the most complete lift thread that people have spent their own time and money discovering things that have never been tried before. right down to measurements, part numbers, pricing, etc. why does coil length even matter if the combination of parts, prices, amoutn of lift, etc has already been well documented? isnt the goal to figure out the amount of lift? even some of the tacoma guys from TTORA have made it over here and read the thread and had great follow up questions.
do yourself a favor read the thread from the beginning. thanks to andy, schaeffer, etc for the thread
bob
Old 01-19-2006 | 07:43 PM
  #737
waskillywabbit's Avatar
Well said as always Bob.
Old 01-19-2006 | 08:10 PM
  #738
sschaefer3's Avatar
Same height as a 1999 4WD V6, 16" wheel coil, just thicker wire.
Everything you ever wanted to know about front coils:
http://www.sonoransteel.com/front_coil-springs.html
Old 02-20-2006 | 09:22 AM
  #739
Yobroe's Avatar
Originally Posted by Bob_98SR5
name,
bob
Bob,
I have to second your sentiments...if it weren't for this thread and the help from these guys taking their own time to put this info together, test it, write and rewrite, I wouldn't have my lift. To anyone with questions at this point in the thread, my suggestion would be to do what I did; Print the whole thread, read it, and re-read it. There are many ways to lift a 4 runner...and there is probably no better thread or more comprehensive group of information about it on the planet--thanks again guys!
Cameron
Old 02-27-2006 | 06:28 PM
  #740
alanbobalan's Avatar
okay. i have read this entire thread, but given there is ALOT of information in here and i'm a little confused. i am a tacoma owner and much of the information in here is geared towards all the runners out there.
ok so having that been said, from my understanding after reading this thread.....
on a 98 4x4 tacoma WITH the top plate spacer i can expect around 2.25" of lift?
WITHOUT the top plate spacer i can expect around 2.00" of lift?
i know it's only a quarter of an inch, but every little bit helps as i'd like to avoid doing a body lift.
