Old 04-21-2016, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
New Suspension Setup - TRD Front Lift for a 3rd Gen 4Runner!
Old 11-24-2005 | 07:41 AM
  #661
ravencr's Avatar
Thanks Steve!
Chris
Old 11-24-2005 | 07:47 AM
  #662
ravencr's Avatar
Actually, Steve, what's the N91 compressed and extended lengths? It's not on that page.
Old 11-24-2005 | 08:14 AM
  #663
sschaefer3's Avatar
Call ARB. I don't know and for IFS it really does not matter. There is such a small window of operation and all you do is stay in that window, if you go outside of it, parts break.
Old 11-24-2005 | 08:22 AM
  #664
ravencr's Avatar
When I did a search for the front springs, here's what I got:
Part Number: 48131AF090 COIL SPRING, Tundra, 4WD, Right, Access Cab, w/Off Road Pkg. 2000 - 2002 $97.93
Part Number: 48131AF100 COIL SPRING, Tundra, 4WD, Left, Access Cab, w/Off Road Pkg. 2000 - 2002 $97.93
Are these right, because you're showing that they are off 2004 Tundras?
Chris
Old 11-24-2005 | 08:28 AM
  #665
sschaefer3's Avatar
Those are the correct part numbers and the coils I used before the far superior leaf springs.
Old 11-24-2005 | 08:51 AM
  #666
ravencr's Avatar
This stuff is so vague! I'm not knocking your part numbers, but it appears that you beleive they are 2004 Tundra springs and partznet beleives they are 2000-2002 coils. What a pain in the butt.
Chris
Old 11-24-2005 | 09:21 AM
  #667
ravencr's Avatar
Ultimate 3rd Gen Lift, just happens to be with all stock factory parts.
2004 Toyota Tundra TRD 4WD Front Coils:
48131-AF090 - right - Blue + Yellow goes on the passenger side
48131-AF100 - left - Yellow + Yellow goes on driver side
These are both pulling up as 2000-2002 Tundra 4wd with access cabs w/ off-road package on both toyotapartsales.com and partznet.com for $91.41 and $97.93.
2004 Toyota TRD Tacoma Double Cab stock front shocks. Order two shocks.
48510-A9160 - Tokico TRD Blue
These pull up correctly for $88.48 & $94.78.
1995 Toyota FZJ-80 Land Cruiser Coils (Yes the front FZJ-80 coils fit in the back of a 3rd Gen 4Runner):
48131-6A570 - left - Orange + Orange + White
48131-6A480 - right - Purple + Gray + White
These pull up as 1993-1994 Land Cruiser coils for $61.10 & $65.45 for the left side, and $60.81 & $65.15 for the right side.
1995 Toyota FZJ-80 Land Cruiser stock rear shocks. Order two shocks.
48531-69486 - Tokico Black
These pull up correctly for $27.10 & $26.84
I'm not trying to confuse everyone, but if a bunch of people are going to start buying this setup, just be aware the part numbers don't seem to all match with the years. But, one major thing I'm noticing is that this is a great lift, and it's really cheap at roughly $540.00 total.
Chris
Old 11-24-2005 | 09:30 AM
  #668
sschaefer3's Avatar
The part numbers are correct, unwad your panties. For example the air cleaner for my 1981 4WD Mini P/U was listed for an 1984 Celica W/O fuel injection.
As hard as it may be to belive but the same air filter was used on a 1981 Mini P/U.
Use the numbers, they are right and stop having a cow.
Old 11-24-2005 | 12:02 PM
  #669
ravencr's Avatar
I'm not having a cow, just letting everyone know they may appear different when they go to place their order at one of those places, that's all!
Chris
Old 11-24-2005 | 01:22 PM
  #670
sschaefer3's Avatar
Chris
Ok, I thought you were having a cow. Maybe your just having a goat or something? A sheep?
Old 11-24-2005 | 02:17 PM
  #671
grimpy's Avatar
are the Tundra coils the same as the 4Runner coils in terms of fitment? I have the 4Runner Bilstein HD's... Can I fit the Tundra coils on them without having to replace it with Tundra shocks?
Old 11-28-2005 | 08:05 AM
  #672
2wheelBLACKOUT's Avatar
yes you can run tundra coils with your 4runner billies, that is what I am running and there are no fitment issues. FYI. I am running NON-TRD tundra coils with 4runner Billies
Old 11-28-2005 | 04:24 PM
  #673
grimpy's Avatar
Sweet... thanks for the info... I'll probably end up doing this sometime in the near future.
Old 11-28-2005 | 05:46 PM
  #674
bamachem's Avatar
i can't IMAGINE how harsh and stiff tundra coils are on billies.
you want a SOFT shock to run w/ them. BILSTEINS are crazy stiff.
Old 11-28-2005 | 06:08 PM
  #675
ravencr's Avatar
I like stiff shocks, Andy. Does anyone know where or if Bilstein has a page on their website inidicating compressed and extended lengths for their shocks?
Chris
Old 11-28-2005 | 08:59 PM
  #676
waskillywabbit's Avatar
Chris
My front Bils extend 14" and the rears 10"...they still got the part numbers on them if you are interested...I'm pretty sure they are 5100 series and the fronts are 48s and the rears are 49s, but if you really gotta know...I can go look and make sure.
Old 11-28-2005 | 09:14 PM
  #677
sschaefer3's Avatar
Front and Rear Bilsteins are as follows:
BF5-A196-H1
10.02" Travel
5150 Crossflow
255/70 valveing
25.91 extended
15.89 compressed
14mm eye/eye
This is on a 1999 4Runner. Minor cutting.
Old 11-29-2005 | 04:45 AM
  #678
bamachem's Avatar
Chris
Bilstein Shocks + Tundra Coils = BRICKS
almost as bad as putting billies on OME coils.
to each his own, i guess... go for it!
Old 11-29-2005 | 07:16 AM
  #679
ravencr's Avatar
I'm actually thinking that I'll get the Tundra coils, try to run them without the top out spacer, but it all depends on how much lift I receive out of the 1991 LC 8 wrap coils I'm getting for the rear. If it ends up being too much rake, I'll add the top out spacer that I've been running for a while.
Chris
Old 11-29-2005 | 07:35 AM
  #680
sschaefer3's Avatar
The Yellow Bilsteins are not the same as the Silver ones.
