Old 04-21-2016, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
New Suspension Setup - TRD Front Lift for a 3rd Gen 4Runner!
Old 11-22-2005 | 05:04 PM
  #641
sschaefer3's Avatar
Originally Posted by gapguy
The only benefit I see here is cost?
That would be the "biggie". Cheap outstanding all OEM lift.
Old 11-22-2005 | 05:14 PM
  #642
garrett1478's Avatar
if the tacoma TRD shocks are used instead of N91S, does this eliminate the need for limit straps?
Old 11-22-2005 | 05:18 PM
  #643
ravencr's Avatar
Steve, if the 7 wrap coils are indeed 1995's. Did you happen to confirm which ones are 8 wraps by any chance?
Chris
Old 11-22-2005 | 05:19 PM
  #644
sschaefer3's Avatar
Yes it does.
Old 11-22-2005 | 05:21 PM
  #645
sschaefer3's Avatar
Chris
No freakin clue. Mine and Jim's both came from bonified 1995's and have the same color codes. The 96 and 97 have different part number and well as the 91-94 have different part numbers than the 95.
Don't know, don't care, buy the 95's. Since I don't have any stock suspension left, my interest in this is limited.
Old 11-22-2005 | 08:29 PM
  #646
crappled's Avatar
Thanks for the help steve..
trd front = 2.5in front
7-coil = 3in
8-coil = ~4in
in the rear, correct?
Old 11-23-2005 | 05:23 AM
  #647
ravencr's Avatar
Well, since mine has the gas tank in the rear, I'd rather get the 8 wrap coils than the 7 wrap's. Thanks Steve,
Chris
Old 11-23-2005 | 05:43 AM
  #648
bamachem's Avatar
The TRD's in the front w/ NO spacer will be 1.5"
With one spacer, it's 2.0"
the 7-wrap coils in the rear are about 3.5" w/o extra weight.
Old 11-23-2005 | 05:46 AM
  #649
ravencr's Avatar
Andy, the spacer is the same thing as the Revtek one I've been running forever, right?
Chris
Old 11-23-2005 | 05:48 AM
  #650
bamachem's Avatar
same as the Revtek Top Out spacer that's 3/8" thick. You'll also need the longer studs in your top plate.
Old 11-23-2005 | 05:50 AM
  #651
ravencr's Avatar
Yeah, I've been running that setup with cornfed spacers for a long time, so at least I don't have to buy anything but the coils for this.
Chris
Old 11-23-2005 | 08:54 AM
  #652
sschaefer3's Avatar
That was the case with us and our winches and TJM and ARB bumpers, but I have done 10+ of these installs locally and the 3rd Gens with stock front bumpers and no winches are up around 2.5" with one spacer.
Obviously the winch/bumper does make a difference. So if your a stocker, try just the coils first.
The exception would be Mark Fit with his crazy brush guard and the stock front bumper on his 2000. That thing sagged every coil thrown at it.
Now he has a T-15 and I bet that problem is solved.
I have some pics of those TRD Tokico's up against some $1000 SAW's. Save your money and go TRD Blue.
Old 11-23-2005 | 11:46 AM
  #653
ravencr's Avatar
Where's the pics located? Also, you're not going to renig on this setup down the road, are you? J/K!
Chris
Old 11-23-2005 | 12:17 PM
  #654
sschaefer3's Avatar
I'll post the pic when I get time. Things change and get better. If we find someting better it will replace this, but at this point, I don't see how you could get any better, the only thing would be to get a 2" lift coil that did not need the top out spacer.
Old 11-23-2005 | 12:40 PM
  #655
Bighead's Avatar
Maybe I'll buy and install a new set of the 95 coils before my drive to Colorado. I can use the extra help in the rear with all the crap that will be packed into the back of the 4Runner.
Old 11-23-2005 | 01:06 PM
  #656
sschaefer3's Avatar
I have a set. You have a set of shocks I want. Lisa has a Double Cab TRD right?
Old 11-23-2005 | 01:13 PM
  #657
Bighead's Avatar
Yep. 2004 4WD TRD D-Cab. The only concern is when I can throw a lift on the truck. When I can get them to you might not be quick enough for your project. We can talk about it when I call this weekend.
Old 11-23-2005 | 02:56 PM
  #658
ravencr's Avatar
I know, just kidding around!
Chris
Old 11-24-2005 | 07:25 AM
  #659
ravencr's Avatar
2004 Toyota Tundra TRD 4WD Front Coils:
48131-AF090 - right - Blue + Yellow goes on the passenger side
48131-AF100 - left - Yellow + Yellow goes on driver side
Is one side slightly longer than the other?
2004 Toyota TRD Tacoma Double Cab stock front shocks. Order two shocks.
48510-A9160 - Tokico TRD Blue
What's the compressed and extended lengths? And, how does this compare to the OME's everyone's been running for so long?
1995 Toyota FZJ-80 Land Cruiser stock rear shocks. Order two shocks.
48531-69486 - Tokico Black
Thanks for the help, Steve.
Chris
Old 11-24-2005 | 07:36 AM
  #660
sschaefer3's Avatar
Yes. Ones a drives side, ones a passenger side.
The front OME shock is too long. Too much droop and the CV's come apart from too much angle. While the OME shock has a nice huge shaft, it is not the best choise here requieing limiting straps to pull it back.
How long is it? Just as long as a set of $1000 Camburg SAW's.
Which are the same as the 2.0 SAW's, which are the same as an Aftermarket Bilstein.
This is NOT the stock black shock that came on your truck.
http://www.sonoransteel.com/rear_shocks.html
It's all there.
