Old 04-21-2016, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
New Suspension Setup - TRD Front Lift for a 3rd Gen 4Runner!
Old 08-11-2005 | 07:37 PM
  #581
francr's Avatar
Originally Posted by bamachem
Valkyrie610 (Chris) on yotatech and tacomaterritory is the owner/operator of toyotapartsales.com. He currently has the lowest prices ANYWHERE for the Tundra Coils and the OME N91s struts.
The coils are $84.52 each from him - cheaper than ANYBODY.
He has the OME N91s struts for $185.28 + shipping compared to $219 + shipping at wheelers!
He's also in the works of getting some studs sourced like wheeler's did and then he would stock my spacers so that he could offer the TRD lift as a bolt-on package with a tacoma top plate!
Make sure to give this guy your business when you shop for parts - he's got great customer service and will match prices that you find anywhere else...
Wow! I wish I'd known that! That is a good deal. Andy, I did some light wheeling around my area here with the front and back sway bar connected. I noticed that my front OME coils have scratches on them that matches the back of the ball joint, so I ordered the mounts from Steve at sonoransteel and the kartek pyrotech straps and adj clevis from protrux here in SD. I'm gonna have them install it. Once my front discos come in from WabFab, I will try wheeling without the sway bar.
I've loaded all my dive gear in the truck and pretty happy with the results. No noticeable degradation in handling compared to the stock coils and struts. I can feel the road much better, though. I am really happy with the setup. Thanks for all the input.
Old 08-11-2005 | 08:02 PM
  #582
waskillywabbit's Avatar
Discos should be there tomorrow/Saturday.
Old 08-11-2005 | 09:20 PM
  #583
francr's Avatar
Brian,
I actually got it today. Question, would the nylock nut become loose after repeated disconnection?
Old 08-12-2005 | 04:27 AM
  #584
Certainly it won't "lock" as well as initially if you take it on/off 150 times a day, but I imagine as many times as you remove it...it should be fine. The reason I used a nylock nut on top is that everytime I had to take them off I had to use pliers to get the wingnut off anyway, so if I was going to have to use a tool, why not just get another nylock nut instead of a wingnut. I think everything will be fine as a nylock nut will be more secure than a wingnut IMO regardless.
Old 08-12-2005 | 04:44 AM
  #585
bamachem's Avatar
yeah, brian and i discussed that issue and both came to the conclusion (ok, he persuaded me) that you might as well have a nylock on there so at least you can get a socket on it. my wing nuts will bind if i'm not parked on a perfectly flat grade, so a pair of pliers was a necessity to get them off anyway.
Old 08-14-2005 | 12:53 PM
  #586
francr's Avatar
Roger on the nylock. I installed them yesterday and when I inspected the old links, the left one is bent for some odd reason. I inspected the stock sway bar and the left one seems a little bent towards the right so that when I installed the discos, the left one is leaning so slightly to the right instead of both of them leaning out. I got my 4Runner brand new and I had one accident where a crown victoria hit my right rear side. Scratched the right wheel and damaged the right rear door. THe frame was tested and it was not bent. Could this be the reason?
Also, Brian, I didn't use your washers. I used the stock concave washers that came with the link assy. I had to slightly widen the center hole with a dremel to fit your disco bar. When I installed it, the sway arm is parallel to the ground. Oh, I changed the old bushings with new oem bushings.
How hard should I compress the rubber bushings? The manual says 51 ft lbs torqu and the bottom connection 41 ftlbs.
One more question. If I go wheeling and disconnect the sway bar, what do I do with the sway bar? Just let it hang?
Thanks
Old 08-14-2005 | 01:07 PM
  #587
Talking
The sway bar might be shifted to one side from the wreck impact, not bent, and that would explain the leaning.
Not a problem, the washers are provided for those that might get new bushings other than OEM and don't want to drill. You can adjust the nylocks on the top threaded stud to wherever you wish to get the angle of the sway bar however makes you most comfortable.
Go w/ the OEM torque ratings as that is really not that much torque if you use a torque wrench, not much more than hand tight.
Yep, that is why they are quick disconnects. The sway bar will be fine hanging.
Anymore questions just hit me up via email or on my quick disconnect thread in the Vendor section so we don't hi-jack this one anymore than we already have.
Old 08-19-2005 | 06:37 AM
  #588
bamachem's Avatar
recent discussions on tacomaterritory have questioned the numbers that steve schaefer and i have for the TRD Tundra and TRD Tacoma spring rates. here's part of the discussion:
http://www.tacomaterritory.com/forum...425#post158425
here's my solution as posted in the thread above:
Originally Posted by hytenor
Let's try quoting a little more of that post or at least the part that states that Downey's Tundra replacement coils used in their coilovers are 800#. The v8 Tundra coils (NON-TRD) are 600s based on info from the spring company that tested them for Downey (call Downey, get the spring company's name/number; it's not hard). v6 Taco coils (NON TRD) are 480 as tested by the same company. The lower portion of the TRD Taco coils are 520 but I don't know what the upper, 'progressive' portion is. NWOR's pr coils are 600/300 and are stiff as hell.
I don't know where you guys get your 475 number from but that is bs for sure. Perhaps the v6 2wd coils are that rating but not the v8s, sorry.
Until I see test figures that differ I'll stick with what I have come up with.
As for Taco owners trying Tundra springs, many have stated that they ride very stiff especially w/o some extra weight on the nose like a winch or winch/bumper.
We can go round and round on this subject but the facts are that the Tundra coils listed by you seem to work great on Runners but do not seem to work as well on Tacomas. I would argue that said coils with either OE tundra shocks or OMEs should do fine on v6 Dcabs with their slightly heavier front ends but the rear sus would need to be balanced to it to produce optimum results...ie, new (softer valved) shocks and possibly leaf springs.
Rick makes a good point about the drastic difference in the rear suspensions between the Runners and Tacomas. If all you do is swap out the front suspension w/o doing the equivalent to the rear the suspension is unbalance and will not ride well, period. I do know from experience that changing the rear shocks from a stiff valving like the Bilstein 5100 (255/70) to a ligher 5125 or 5150 with 170/60 valving makes a huge difference in overall ride/handling...and I do mean drastic.
Perhaps Runners have a much softer rear suspension than what you see on the average modded Tacoma on this forum (since 5100s seem to be the shock of choice around here).
I know for a fact that all the OME coils, 880-882, are 500# and the Tundra v8 non-TRDs are 600s (figures directly from ARB and the spring Co. that tested springs and manufactures them for Downey). If the 2wd TRDs are lighter then that might explain the difference you Runner guys are coming up with as far as ride goes. But, understand the progressive rate coil; they will have two different rates with the top section being much lower than the bottom section.
check out the BOLD sections in your posts above and i think you might find the answer...
the NON-TRD coils are stiffer at the OME coils. how do i know? I ran them on my 4Runner a long time ago. I had 2WD V8, NON TRD Tundra coils and they sucked ass. the NWOR coils that you reported as stiff may have felt that way cause the lower spring rate was too low and was completely "used up" with just supporting the taco - that would explain the STIFF ride fully. also, IN YOUR OWN WORDS, the upper section of the TRD springs are MUCH softer than the lower section. we also know that the upper section is softer than the NON TRD versions due to the vast difference in ON-STREET rides. NWOR's difference in the progressive rates was 50%. if TRD used as little as 20% and the 520 #/in number you stated is indeed correct, then the upper portion would be in the 420#/in range - EXACTLY where my number that I have puts it. That's only w/ a 20% difference from the "soft" section to the "stiff" section. Think about that while I do some math...
you like HOE's right? well, according to: Donahoe Racing
Originally Posted by donahoe racing
If you want the best ride, this is the ticket. Donahoe Racing spent several months developing valving and spring rates for the perfect Toyota shock. This front suspension system features a 2.5" diameter nitrogen-charged race style coil-over front shock. The spring gives you a 15% increase in spring rate on a Tundra and 30% increase on a Tacoma. The system also allows for an additional 0"-3" lift to provide increased performance and clearance of larger tires.
now, there are two arguable values for the Tacoma Coil Spring Rates. They have been reported by some to be in the 420#/in for the TRD soft section of the coil (the part that's used ON-ROAD) and according to Downey, they NON-TRD coils are 480#/in. I'm not disputing that rate at all for the NON-TRD coils or the 600#/in rate for the NON TRD Tundra coils. We aren't talking about those coils however, so those numbers aren't really valid in this case except for "seat of the pants" comparisons only. I'll cover both of those rates in my math, however:
Known:
Taco Spring Rate = 420 #/in (assumed to be correct for this illustrtation)
hoes = 1.15*(Tundra Spring Rate) = 1.30*(Tacoma Spring Rate)
Unknown:
Tundra Spring Rate = X
so, time for some Algebra:
1.15*X = 1.30*(420)
X = (1.30 * 420) / 1.15
X = 475 #/in
and if the Tacoma Spring Rate is actually 480 #/in, then:
1.15*X = 1.30*(480)
X = (1.30 * 480) / 1.15
X = 542 #/in
BUT, this isn't the spring rate for the TRD taco coils, as you and I agree.
We take it as gospel that that OME coils are indeed 500 #/in, and I agree. I've had the OME 882's up front w/ OME N91s struts and the same bumper, winch, etc. The 822's (that I had) felt stiff as hell - no joke - and I felt every bump in the road. They were linear spring rates and therefore the feel didn't change under minor or severe compression or at any speeds. The TRD coils are Progressive - everybody will agree to that.
I think the difference in numbers that we're getting is the difference in the upper and lower spring rates for the progressive coils as I stated above. It makes sense once you think about it. The lower rate for tacos is prob the lighter section of the spring and the higher number is the stiffer section. I already showed that w/ your lower section number of 520 #/in, my number of 420 #/in for the upper section happens to be exactly a 20% difference in the rates - not a coincidence if you ask me.
About the only way that I'm EVER going to prove EXACTLY what the spring rate is in my 4Runner w/ the TRD setup is to measure it. I'll take some accurate (to w/in 5# easily) bathroom scales w/ me to Tellico on the Fall colors run that's Sept 16th-18th. I'll weigh a few people and then measure the deflection of the 4Runner as they stand on the front ARB. I'll get several people on there (600-800# and take measurements for each person) and use the total weight and the total inflection to get the combined spring rate for the front two springs as an average. Once I know that, all I do is divide by 2 to get the individual spring rate. If I get several people in the 200# range, then the deflection should be close to 1"-2" (assuming that the rate is somewhere between 450#/in and 600#/in) and since it can be measured to the nearest 64th of an inch, that would yeild an approximate accuracy of +/- 10#/in (actually it would be +/- 7.8#/in so I rounded up).
That should settle this once and for all. Hopefully we can do it w/ someone w/ OME's and maybe if someone w/ stock Taco coils will show up we can do it on it too.
FAIR?
Old 08-21-2005 | 07:01 PM
  #589
plzsno24's Avatar
Prices
Andy, where are you ordering all this from, at the sweet price? I am working on my lift, and trying to save a buck.
Old 08-21-2005 | 07:15 PM
  #590
garrett1478's Avatar
www.toyotapartsales.com for the tundra coils
www.4x4connection.com or www.wheelersoffroad.com for the OME parts
Old 08-21-2005 | 07:22 PM
  #591
valkyrie610's Avatar
Hate to brag, but we have always been less expensive than either of those guys for OME parts...
https://www.yotatech.com/forums/show...08&postcount=1
Old 08-22-2005 | 07:54 AM
  #592
bamachem's Avatar
No doubt the best prices around for OME parts and TRD Tundra Coils!
Also, I have another 32 pairs of spacers on order. Unfortunately, the CNC shop that cuts them have increased their rates slightly along w/ a slight material increase. Therefore, my pricing has to go up just a tad. I'm absorbing some of the costs as well.
The new pricing is $40 for one pair SHIPPED via USPS Priority Mail and $75 for two pair - shipped also via Priority Mail.
I have a new page w/ Paypal direct links to buy them at : http://4rnr.net/suspension
Old 08-22-2005 | 04:19 PM
  #593
ravencr's Avatar
Now doubt the best prices around for OME parts and TRD Tundra Coils!
Andy, did you ever run stock 4runner coils with the Cornfed spacer and 3/8 top out spacer to compare?
Chris
Old 08-22-2005 | 06:45 PM
  #594
bamachem's Avatar
Chris
well, yes and no... that was the first setup i had - minus the top out spacer. the top spacers don't add any preload, so they don't change the feel, just the ride height. then i went to tundra non-trd 2wd coils w/ the same cornfed spacers, then to ome 882's then back to the non tundras, then to the current setup...
Old 08-22-2005 | 08:02 PM
  #595
sschaefer3's Avatar
Chris
Banjo saw some new things...................
Old 08-22-2005 | 08:12 PM
  #596
Were there "dueling Banjos"?
Old 08-22-2005 | 08:19 PM
  #597
sschaefer3's Avatar
Nope. Chris can fill you in, it will be funnier/better coming from him.
Old 08-22-2005 | 08:21 PM
  #598
Okay. Let's hear it Chris...start a new thread and let's hear ALL about it.
Old 08-23-2005 | 04:58 AM
  #599
bamachem's Avatar
oh please elaborate...
Old 08-23-2005 | 06:04 AM
  #600
ravencr's Avatar
Not much to tell, other than Steve named be Banjo I guess because I'm a redneck from the hills of East TN, my mods make him laugh, the wording of some of my threads really make him laugh, etc. It is all in fun, and I'd be worried if he hadn't harrassed about me about my "New Cheaper Plan" over 40 times in one weekend. That was the running joke of the weekend!
Steve, does that accurately sum up the reason I was named "Banjo"?
Chris
