Old 04-21-2016, 12:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
New Suspension Setup - TRD Front Lift for a 3rd Gen 4Runner!
Old 12-13-2004 | 10:03 PM
  #401
JonnyOzero3's Avatar
2" or 2.5" no spacer?
Hmm...okay. I am a little confused because Gumbo on his 96 4x4 Xcab Tacoma got 2.5" of lift (post #158) with no spacer - that seems to imply a measuring problem, weight difference, or different coil in comparison to the 4runner results (I think). I PM'd him for more info...
(thanks btw, seems like a nice forum you guys have over here)
Last edited by JonnyOzero3; 12-13-2004 at 10:17 PM. Reason: extraneous junk info because its late at night...see you tomorrow
Old 12-13-2004 | 10:25 PM
  #402
RTdawgs's Avatar
Originally Posted by sschaefer3
You’re only going to get 2" of lift even with the top out spacer, which goes outside the pack. The Tundra coils are really only good for 1.5 on their own.
Paul (Bratik) got the same amount of lift from the Tundra/Topout combo as he did with 882s, just under 2.5" lift (ARB Sahara and Warn9500).
Old 12-14-2004 | 03:58 AM
  #403
sschaefer3's Avatar
My extremly heavy 2.7 liter 4 banger and TJM with M8000 only pulls 2" even.
Now the lift most certainly changes after your alignment. It's alot higher before the alignment.
So you should pull your numbers after the alignment and a least one good wheeling trip.
Old 12-14-2004 | 04:26 AM
  #404
bamachem's Avatar
I've had several taco owners using the 4WD TRD coils and a single spacer on each side and they all claimed to get 2.25" - without talking to each other and without me mentioning that number. I guess the Taco really is that much lighter up front.
I've got 2". So does Steve. Gapguy has 2.5", but he used a double spacer on each side.
Old 12-14-2004 | 04:41 AM
  #405
sschaefer3's Avatar
Which makes sence because a Tacoma will gain 1/2" of lift from a set of 99 front 4Runner coils.
I have a set of 2001 and 1999: V6, 4WD, SR5, 16" Wheel coils.
The 2001 have 8 winds and the 1999 have 9. So now I have cold hard facts that 2001 and 2002 did in deed have shorter coils. The 1998 coils I had were shorter as well. 8 winds versus 9. The Tundra coils are the same 9 winds as the 99 4Runner coils as well as the same hight, the wire is thicker.
Old 12-14-2004 | 04:42 AM
  #406
Bratik's Avatar
I have only one spacer, and my alighnment is done it's max out and I got around 2.5. I realy like how this set up rides.
Old 12-14-2004 | 06:32 AM
  #407
TacomaTRD's Avatar
I have a 98 Taco TRD Stock, I was going to replace the shocks in the next 5K miles (71K on truck)
I would like to go to 33" tires, can I achieve this w/out a 1" body lift by going with TRD coils/shocks and spacer? I plan on wheeling it, but not to aggressively...
If so, what is the recomended setup?
TIA
Old 12-14-2004 | 09:28 AM
  #408
User 051420's Avatar
TIA
You *can* clear the 33's with only this setup, but it's going to take a bit of hacking. Try searching for "pinch weld". Personally, I went the BL route and it works very well for me.
Old 12-14-2004 | 12:10 PM
  #409
all better now
Okay that makes sense...I also talked to Gumbo and he stated his original coils were saggin to begin with, so that explains the extra lift he saw. So I can expect 2.25" with a single spacer on each side for my Tacoma. Awesome.
Old 12-14-2004 | 12:27 PM
  #410
TacomaTRD's Avatar
OK Thanks, I did a search on the "pinch weld" and "pinch weld mod" and couldn't find any detailed info. Maybe I will do a 1in lift and do the coil change. I have a auto on the TRD, that seems a bit more difficult to lift then a stick. I have a couple friends with mod'd sticks, had to reweld the shifter on one at 11pm after it broke because of the ˟˟˟˟ty welding by the shop that lifted it.
Can anyone reccomend who makes the best 1in lift kit?
Old 12-14-2004 | 12:49 PM
  #411
Roger Brown aka 4Crawler!
http://www.4crawler.com
Old 12-14-2004 | 01:07 PM
  #412
bamachem's Avatar
The auto isn't any trouble w/ a 1" kit.
RB has the best ones - abotu $100 or so.
see http://www.drawhorn.org/pinch_weld_trimming.htm for pinch-weld pounding procedures
Old 12-14-2004 | 03:40 PM
  #413
hytenor's Avatar
cool thread but, dang...long.
There have been a few inquires on the ttora board in the last year or so about using Tundra coils on the Taco but I've only seen a couple who have tried it. those that have had/do have them tried it to support a heavy winch/bumper AND maintain lift. Their ride was stiff but managable.
Do you know what the weight ratings are for the varrious Tundra coils? Downey claims 600# for the v6 and 800# for the v8 for their Tundra coilover kits but these figures are something like 30% higher than OE according to their cataloge. I know the Tacos (prerunner and 4x4) have 4 different rates that available depending on engine, model, 4x4, 4x2, TRD/non-TRD, etc. and the range from around 385 to 520#. I see from a couple of your posts that the Runner coils are taller and heavier than the Taco coils...good to know. I didn't even know they were interchangable.
I'm guessing the Runners are quite a bit heavier up front than the Taco and our OE bumpers only weight about 8#, LOL
the question of whether OME N91s are longer is correct, about 1/2", at least from OE shocks on the Taco.
As for the other question of more droop I would suspect the 3/8" top-plate as they will alter the stock geometry by pushing the shock/coil assembly down giving that much more in down-travel. Several taco owners I know have hyperextended a tripod joint with this setup so limit straps are a must if you really flex things out.
speaking of straps...where do you get them? I need one for my pass side.
thanks
Old 12-14-2004 | 04:08 PM
  #414
tulsa_97SR5's Avatar
Ot
Can't answer, I actually have some of the same questions. Wondering if maybe we can start to compile some size & rough spring rate estimates for all these. I'm really curious about the if the rear sequoia springs might be a possible fit for the 4runners. Seems like sequoia's are about 300lbs extra on each corner & I could see that they might work well.
Mostly wanted to welcome Hytenor to the site & see if you have a website, or a bigger pic of your avatar?!
Old 12-14-2004 | 04:19 PM
  #415
hytenor's Avatar
I would wonder about the Sequoia springs being too heavy for the runner and limiting flex but if you can find out what the rates are you could come up with some good estimates of lift, load capacity, etc.
A comprensive list of spring rates for all the different coils that fit on the Runners, Tacos and Tundras would sure be nice. I know all the OME 880-882 series are 500# using the same wire. NWORs Pr coils for the Tacoma are 300/600. Older SAWs used 500" coils but the newer ones are 650 and 675. Donahoe, Camburg and King all use 650# coils now. I haven't seen figures for Fabtechs coilovers. all this for the Taco; don't know about the Runner.
I don't have a website but here are a bunch of pics on my norcal ttora page:
http://www.norcalttora.com/~chris/wheelin%20trips/
I haven't wheeled with too many Runners, just Demello (in his wife's rig) and one other (SA rig) on the Rubicon last year.
Old 12-14-2004 | 04:58 PM
  #416
bamachem's Avatar
IIRC
Taco TRD 4WD front coils are 430#/in
4Runner front coils are 450#/in
Tundra TRD cois are 475#/in
Go back to the original Tundra TRD Coil Thread discussion and it's in there somewhere becasue I dug it up...
Old 12-14-2004 | 04:59 PM
  #417
Didn't Steve say the Tundra coils were much softer?
Edit: Nevermind..softer than 4R coils WITH spacers.
Old 12-14-2004 | 05:03 PM
  #418
hytenor's Avatar
IIRC
Hm, I got 4 different rates from my local parts guy depending on the varrious combinations of v6, 2.7, reg cab, ex or Dcab, prerunner/4x4. The v6 4x4 dcabs should be 520#. What I don't know is are any of these different lengths like OME has.
Plenty of taco owners with 2.7s have swapped to v6 coils for an extra 1" of lift.
I'll check the thread, thanks
Old 12-26-2004 | 06:41 PM
  #419
sschaefer3's Avatar
So I drove over to the land of Bling Bling.
Guess what? I could go ALOT faster with the Tundra/Old Man Emu than I ever could with the Sway-A-Way Racerunners I once had.
I went 3 valleys into the dunes from the Gecko Campsite. I did not want to get stuck with a 5K truck. So I did not go too far in. But it did really well and I did do quite a bit of tooling around the campsite with the sand limos.
Very very impressive how unbelievably well this setup did in So Cal. Coil-over land.
Rockcrawler soft and Bling Bling fast. I can't believe it does both..........
Old 12-26-2004 | 06:48 PM
  #420
Go team TRD Coils!
Quick Reply: New Suspension Setup - TRD Front Lift for a 3rd Gen 4Runner!
