Old 04-21-2016, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
New Suspension Setup - TRD Front Lift for a 3rd Gen 4Runner!
Old 11-30-2004 | 11:09 PM
  #381
2wheelBLACKOUT's Avatar
how will this set up work with daystar 2.25" coil spacer and studs..? (tundra coil + ome n91shocks + daystar 2.25 coils n studs) would this be to much lift.? whats your opinion..? thanks in advance
Old 11-30-2004 | 11:10 PM
  #382
User 051420's Avatar
Too much lift, too stiff..
Old 11-30-2004 | 11:12 PM
  #383
what if i run softer shocks..?
Old 12-01-2004 | 06:09 AM
  #384
sschaefer3's Avatar
Originally Posted by RTdawgs
any new updates?
Steve? how they flexing?
Incredable. A significant improvment over even the Frankensein Cronbred/Revtek/99 Coil setup.
As far as I'm concerned, Cornbred, Revtek and Daystar should all be out of business. This is by far the best lift bar none in my opinion.
Also keep in mind that the Sequoia coils are even longer yet. That is uncharted territory, and I don't really see a need to go there, the Tundra/Revtek-Andy top out works so well. If these Tundra coils are TRD and Progressive, Hey I really like them. I can haul botty on dirt roads and go slow over rocks. These things RULE!
Get the TRD 4WD Coils !!!
Old 12-01-2004 | 06:10 AM
  #385
sschaefer3's Avatar
That would be a complete and utter disaster.
Old 12-01-2004 | 10:36 AM
  #386
yeah i figured it would be to much lift...i just wanted to recycle my daystar spacers and studs that i have..but i guess ill just look in getting cornfeds..1-1.5" perhaps..but thanks for the heads up...
Old 12-01-2004 | 10:38 AM
  #387
Can't he re-use his Daystar Studs with the Tundra coils??
Old 12-01-2004 | 10:40 AM
  #388
Are you planning on use a 1-1.5" spacer with the Tundra TRD coils? DON'T! It's just going to stiffin up and you won't flex. The Tundra coils with two top spacers is the most you should go.
  #389
sschaefer3's Avatar
Any spacer with the Tundra coils will defeat the purpose. If you want to use spacers or want to have more than 2" of lift.
THIS IS NOT for you.
Yes he could re-use the Daystar studs but not the spacers.
  #390
bamachem's Avatar
Use the Daystar studs w/ my spacers. I sell Daystar studs, not Revtek. Just don't re-use the Daystar spacers.
Old 12-01-2004 | 11:11 AM
  #391
thanks for clarifying..im such a noob idiot ..but i am getting so much useful information on this set up from you guys..you guys rock for pioneering this ohh another question..if i use 2 of your 3/4" top out spacers..wouldn't that be the same results as a 1.5" cornfed spacer.? please clarify. thank you.
Old 12-01-2004 | 11:15 AM
  #392
bamachem's Avatar
nope. my spacers are 3/8" thick and go on the top of the coil retaining plate. 3/4" thick (2 spacers) will yeild 1" of lift, but OUTSIDE of the coilpack. Cornfed spacers are INSIDE the coilpack and yeild a stiffer ride than outside-the-pack spacers. I don't know why, but they do and anyone who have run both kind will agree.
Old 12-01-2004 | 11:51 AM
  #393
sschaefer3's Avatar
You will have too much droop, bad idea.
Old 12-01-2004 | 11:54 AM
  #394
what results can i yield if i use NON trd 2wd tundra coils..i got some for a really good deal..
Old 12-01-2004 | 11:55 AM
  #395
"droop" do you mean sag in the rear end..?
Old 12-01-2004 | 12:08 PM
  #396
Ehinfinity's Avatar
No, to much down travel in the front, which would result in broken parts
Old 12-13-2004 | 11:52 AM
  #397
tweeker4X4's Avatar
Wow I read this entire thread. My head hurts and almost everything I needed to know was on the first couple of pages. This setup sounds great and it looks like I wasted my money on the OME front springs which I havent even seen yet. Se-la-vi thanks for all the work guys.
Old 12-13-2004 | 01:13 PM
  #398
Ehinfinity's Avatar
Yep, if you can send them back and get a pair of the TRD coils, just made the switch and the ride is much better than the OME.
Old 12-13-2004 | 10:20 PM
  #399
JonnyOzero3's Avatar
Question top out spacer required?
Wow, great thread guys. Thanks for keeping it updated too. I am a TTORA guy and I think I will be hanging out here a bit more often for info. I have read the entire thread but am a little hazy on one thing - are the top out spacers outside ontop the coil necessary or optional? And if I achieve enough lift (2.5") by doing this tundra coil install on my 4wd V6 Xcab Tacoma without them, is there then any reason to install bamachem's custom spacers? Other than that question, I am seriously considering this option to fix up my lift...my kidneys will thank you....
Old 12-13-2004 | 10:37 PM
  #400
sschaefer3's Avatar
You’re only going to get 2" of lift even with the top out spacer, which goes outside the pack. The Tundra coils are really only good for 1.5 on their own.
What you will get is a front Suspension that works beyond belief, it will compress with very little effort. Keeping the tires on the ground a lot more.
I know that SAW's are supposed to be for high speed desert, but I have never been able to go as fast as I can now, even with SAW's?
Quick Reply: New Suspension Setup - TRD Front Lift for a 3rd Gen 4Runner!
