Old 04-21-2016, 12:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
New Suspension Setup - TRD Front Lift for a 3rd Gen 4Runner!
Old 10-25-2004 | 03:24 PM
  #201
Albuquerque Jim's Avatar
Steve & Andy,
Are you taking into consideration that your measurements are some what off due to #1 how far Andy's flares stick out VS non on Steve's? That would increase Steve's #'s in comparison wouldn't it? Also, Steve has to measure around that huge 35" tire VS Andy's 33"
I think the only way to actually compare apples to apples would be to use a yard stick or something perfectly vertical.
Old 10-25-2004 | 03:33 PM
  #202
justinh's Avatar
are y'all using the rubber isolator inside the coil assembly? I used it with mine, i have the yellow/yellow, blue/yellow coils with OME n91S shocks, no body lift on a 1997 Limited, my measurements are:
22" front center of hub to bottom of Flare on both sides, i sit even f/r with my 891's with the conical bumpstops, the 891's haven't been flexed much but do have 20,000 miles on them.
i seem to be higher than most people, i bought the springs used so i don't think it is a new issue. I have no aftermarket weight on the front end at all. I bought a rev-tek top out spacer but it made the strut assembly too long to install even with the upper ball joint nut loosened way up and jacking down on the control arm. There is definitely more coil interference with the Tundra coils, they are much bigger around than the OME's.
i love the way they ride!
Old 10-25-2004 | 03:46 PM
  #203
User 051420's Avatar
If SS3 can run 35's with a 1"bl...anybody can run 285's with no body lift. It's a matter of hacking away!
Old 10-25-2004 | 03:52 PM
  #204
So no 3/8" top spacer? Your number is the same as mine, except I don't have the limited flares. How much can those big flares really hang down? Yes I am using the rubber isolator.
Old 10-25-2004 | 04:02 PM
  #205
justinh's Avatar
no spacer at all. just the factory toyota rubber isolator.
as far as the flares, i really don't think they are much lower than your chrome trim. our measurments sound about right considering your front bumper. do you have a body lift? did you include it in your measurements?
Old 10-25-2004 | 04:05 PM
  #206
I have a 2" BL..it has been considered, and the final numbers are correct. I'll take numbers again soon to see if I've lost anything.
Old 10-25-2004 | 04:09 PM
  #207
Bighead's Avatar
Does somebody happen to have the extended lengths of the Bilstein and OME shocks? The rear Bilsteins (BE5-2451) and the OME N86 have a difference in extended lengths of ~1" (Billie: 20.2" vs. OME: 21.2"). Would it make sense that the matching front shocks would have the same difference in their extended length? That combined with the slightly longer ATS arm length over the stock control arm might be the contributing factors to Steve's extra droop.
I am not a smart suspension guy so if my assumptions are off (read: stupid) please tell me so.
Steve: Any thoughts on how you plan on mounting the limiting straps up front?
Old 10-25-2004 | 04:33 PM
  #208
justinh's Avatar
i have a 2" bodylift sitting in my 4runner, right now, i am not sure if i am going to use it or not, i want to put on the 17" tundra/seq. wheels with some 35's, i will probably end with h2 take offs cause i can get those locally for about $250 a set.
Old 10-26-2004 | 05:08 AM
  #209
bamachem's Avatar
Originally Posted by Albuquerque Jim
Steve & Andy,
I measured vertically and not "around". I put a construction level on the center of the hub sticking out, then measured from the floor to the level. I then put the level at the bottom of the fender flare, then took that measurement. I then subtracted the hub measurement from the flare measurement to get something that we can all compare numbers with since different tires and wheels can throw off other types of measurement methods.
Originally Posted by Bighead
...That combined with the slightly longer ATS arm length over the stock control arm might be the contributing factors to Steve's extra droop.
Well, I have over 3" of droop where Steve has only 2.75". However, it appears that something else is going on here because Steve is also sitting almost 1.5" higher "at rest" according to his measurements. The only thing that I can think of is that he put one end of his tape measure at the center of the hub and the other end at the fender and allowed it to "wrap" around the tire, elongating the measurement.
Old 10-26-2004 | 05:57 AM
  #210
sschaefer3's Avatar
Well, Yeah. Those 35's are BIG.
So how do you want me to do it?
Old 10-26-2004 | 06:10 AM
  #211
bamachem's Avatar
Old 10-26-2004 | 06:34 AM
  #212
sschaefer3's Avatar
OK with the level, center of hub to fender: 23.25"
Old 10-26-2004 | 06:37 AM
  #213
sschaefer3's Avatar
So if you take off 1/2", We went out to dinner last night and there was a 3rd Gen with Limited flares, you right they only hang down 1/2" lower, just like the goofy chrome strips.
I'm the same as you.
Old 10-26-2004 | 06:48 AM
  #214
bamachem's Avatar
Ding Ding Ding
It's about time we all got on the same page...
Ok, then all our numbers agree...
4CYL 4WD, 6CYL 4WD SR5, 4WD Limited... It doesn't matter... All will get ~2" of lift.
Steve, now with that being the case, are you SURE you're only getting 2.75" of droop? I got 3" and wasn't maxed out - upper arm wasn't touching the coil yet... You don't think the front N91s' are SHORTER than the TRD Billies, do you?
Old 10-26-2004 | 06:52 AM
  #215
It works, it works!!!!
Anybody wanna try SAW's?
Old 10-26-2004 | 06:56 AM
  #216
sschaefer3's Avatar
It's not the upper arm, it's the back of the ball joint hitting the winds in the coil.
Maybe I should try measureing that again. Like from the top of my tire level and then the top of the tire drooped.
Old 10-26-2004 | 06:59 AM
  #217
bamachem's Avatar
Maybe so... I'll get my full droop measurement when I go home for lunch in about an hour.
Old 10-26-2004 | 07:29 AM
  #218
RTdawgs's Avatar
...i have the yellow/yellow, blue/yellow coils with OME n91S shocks, no body lift on a 1997 Limited, my measurements are: 22" front center of hub to bottom of Flare on both sides...
These numbers are consistent then. If you would have been installed the Revtek top spacer, that puts you at 22.5" with LTD flares, the same as Andy and Steve (adjusted).
Old 10-26-2004 | 07:52 AM
  #219
sschaefer3's Avatar
I have 2 5/8" of droop from sitting level in the garage to jack the front wheel up so it hangs.
The Ball joint did not hit the coil without the Revtek, So I'm thinking all I have to do is pull it back 1/8" of droop of so.
Old 10-26-2004 | 07:58 AM
  #220
sschaefer3's Avatar
Well I found the sweet spot for the droop. Looks Like I'll have to pull it back 1/2"
So after the straps I'll have 2 1/8" of droop, which is pretty good considering 2" have been eaten up by the lift.
Maybe the upper arms are not all that. I do need some sort of shaved stock arm. Problem is that I beat my stock arms up years ago trying the hammer/pop method on the ball joint. So I would have to get some junk yard ones or buy new ones.
If Andy can get it to droop furhter with the stock arms. Then these ATS arms are going in the trash.
Quick Reply: New Suspension Setup - TRD Front Lift for a 3rd Gen 4Runner!
