New pads and rotors
Old 02-01-2005 | 01:38 AM
Alin10123's Avatar
New pads and rotors
Hi,
I'm about to do a brake job on my truck. Any recommendations? I've never done this before. I'm putting in new rotors and new pads in the front and i will adjust my rears. I hear things about bleeding, do i need to bleed after i swap out pads and rotors? How do you bleed? and what's this thing called a bleeder valve?
Any recommendations on the rears?
This is a 3rd generation limited. 2000.
thanks
Old 02-01-2005 | 01:44 AM
epic37311's Avatar
https://www.yotatech.com/forums/show...=brakes+runner
This might help newbie
epic37311's Avatar
post #4
Old 02-01-2005 | 05:16 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
As long as you don't open the system you don't need to bleed unless you suspect you have air in the system. I did the Brembo rotors/PF pads about 9 months ago and didn't need to bleed the lines.
Old 02-01-2005 | 03:31 PM
Alin10123's Avatar
Originally Posted by epic37311
post #4
Post #4 doesn't say anything about bleeding.
It only states that the brembos + pf pads were a pretty good combo.
Is that what you were refering to?
I already ordered the powerslots and plan on getting the PF pads locally.
Is that a good combo as well?
Old 02-01-2005 | 03:48 PM
SkyRat's Avatar
I have the powerslots on now for almost a year. I love them. They are designed to use with the Hawk pads, but since I bought mine through Performance (because they are only 15 minutes away and I needed them that day) the Performance Products pads came free with the new rotors. They have been great!
Old 02-02-2005 | 08:49 PM
Alin10123's Avatar
Sweet! thanks for all the input. Anyone else with powerslots want to put any input in?
also, in the future, when i change pads and not the rotors. Do i still need to machine the rotors?
Old 02-02-2005 | 09:15 PM
uboatcmndr's Avatar
Hmmmm. I need to bleed as well to put on my new brake lines from WHEELER'S. Good luck bro.
Old 02-03-2005 | 01:35 PM
Alin10123's Avatar
Ok... so i got my torque wrench from Tirerack.com today. I slipped on the 1/2 inch to 3/8 inch adapter since my socket set was 3/8's and i tried to retorque my lugs on my wheels just to practice and test it out for when i do the brakes. I heard a "click" while tightening the first lug and i assumed that was the wrench's way of telling you that it was finished? I then moved onto the opposite lug, and then right before i heard the click, the wrench spun free. I'm thinking WTF? I looked down and the socket was still onto the lug and i was holding the torque wrench in my hand. The adapter had broken off.
Get this, i called tirerack and they said that since the adapter doesn't come seperate, that they would ship me out a new torque wrench. I asked if i had to send the old one back and they said no.
Am i missing something? They're sending me out a whole new torque wrench just because my adapter broke? haha... sweet! these guys are awesome!
By the way, am i using the torque wrench properly?
I just want to make sure since i'll be doing my brake job this weekend.
thanks
ladybugRC
458
08-21-2020 11:41 AM
Kamaloha
10-16-2015 06:13 PM
the_supernerd
10-01-2015 10:20 PM
hiluxinargentina
09-30-2015 06:51 PM
Toys4parts
09-26-2015 02:56 PM
