New Mod: 3.4L TB Bore Mod, “O” Gasket Mod, and PCV Breather Mod – with pics
Old 08-26-2003 | 09:04 AM
rimpainter.com's Avatar
Originally posted by 4RUNR
Just curious if you've heard of it.
No, but that makes sense. There would definetly be a vacuum created by the intake manifold. The PCV valve should open up the higher the pressure (or blow-by) there is from the crankcase. With a Type R breather, you avoid the valve and the minimal amount of hot air going to the intake manifold all together.
I would rate this mod as cosmetic more than anything. Maybe .1HP.
Old 08-26-2003 | 03:09 PM
landman's Avatar
Wil removing the PCV valve allow the unburned fuel pass through the exhaust and damage the O2 sensor? Or will the ECU adjust to make the engine run more lean?
Old 08-26-2003 | 03:24 PM
No and no. We are talking about crankcase ventilation which has no direct part in the combustion process. Unburned fuel is controlled by timing, air fuel ratio, and the effectiveness of the catalytic converter.
The hot rod guys almost always run crankcase breathers on their V8's. I ran one on my old Mazda Truck and my old Civic SI for years. Must have lost .5 seconds in the 1/4 mile...
Old 09-04-2003 | 11:24 AM
I thought I would follow up and mention that my 3rd gear 5K RPM and above power seems to be slightly better, and smoother.
I thought I would throw that out there for anyone considering this mod. I still have to get a write-up going for it.
So far so good.
Old 09-04-2003 | 11:31 AM
  #25
Tacoma Dude's Avatar
Swweeeeeeeeeeeeeeet!
Looking forward to seeing that!
Old 09-04-2003 | 03:17 PM
  #26
KING's Avatar
I see alot of room for a SUPERCHARGER!
Old 09-07-2003 | 03:32 AM
  #27
03TundraTRD's Avatar
How hard is it to remove the TB I want to check if my 03 V6 has the D inted of the O haped gasket
Old 09-07-2003 | 07:52 AM
  #28
2001Millrunner's Avatar
OOH IM GONNA SELL THIS ON EBAY!!!!!!!!!!! HAHAHAHA
Old 09-09-2003 | 04:43 AM
  #29
96Runner
What did you do with the Hose connected on the intake pipe right befor the TB did you leave that on.
Old 09-09-2003 | 07:08 AM
  #30
If you are talking about the hose with a metal fitting that plugs into the back side of the intake track, then yes I left that on.
Post a pic if you have any further questions about it.
Old 09-09-2003 | 07:20 AM
  #31
TOR
Gaskets
I'll get you 20 of them if you want.
Todd
Old 09-09-2003 | 07:25 AM
  #32
Seriously Todd? My other source is flaking out on me. How much?
Old 09-09-2003 | 09:12 AM
  #33
TOR
Gaskets
I don't have them in stock currently, looking at 3 to 5 business days for me to get them.
22275-20010 Gasket $2.43ea
Total w/ shipping $54.60 to your front door.
Let me know
Todd
Old 09-09-2003 | 09:34 AM
  #34
You sure its the non-D gasket?
Old 09-09-2003 | 09:40 AM
  #35
TOR
D-gaskets
No, I can't be positive until I have one in my hands although I bet it is. I will order one tonight and see what it looks like tomorrow and report back with you.
Todd
Old 09-09-2003 | 09:37 PM
  #36
96Runner
What size is the Crank case breather and what else do you have to do when pulling out the hose from the engine block.
Also, is there a spring or valve where you put the breather on. I read on custom tacos that you have to remove the valve or spring(this was on a 2.7) or else you will have long term problems.
Old 09-10-2003 | 07:12 AM
  #37
Originally posted by 03TundraTRD
96Runner
The grommet, PCV valve, and vacuum line all come out. This is what you are left with:
Then, just plug in the breather. Now plug off the fitting at the TB. That's it you're done.
As for the size, well I would have to check on that. I just grabbed a breather at the local Type-R store and got lucky. You can tell what size you need by looking at the grommet when it's out.
Old 09-15-2003 | 07:16 PM
  #38
Detcord's Avatar
Did you bother capping off the other side of the PCV system?
The other valve cover has a hose that connects infront of the butterfly (hi side)
Just wondering.
Detcord.
Old 09-16-2003 | 07:15 AM
  #39
Just wondering.
Detcord.
Yes, I address that in the original post. You can cap it off a number of ways, but I used a drip system irrigation plug with a vacuum line. I did not remove the fitting in case I wanted to put it back to stock quickly.
Old 09-16-2003 | 01:58 PM
  #40
Detcord's Avatar
I meant the tube with the metal fitting....saw a previous post where you addressed the fact that you left it in.
I would seriously suggest removing this line, as it will allow air to enter crankcase and then go into the TB putting the blow off gas right back into your intake and this time infront of the butterfly. This will gum it up nicely.
Just a suggestion, but since the original design was to use filtered high side intake air to move through the crankcase and then into the low side of the intake I would be hesitant to leave your breather assembly as is.
Seeya
Detcord.
