New Idea on How to Run 2 Topouts...
Instead of limiting straps...how about stacking washers and bringing up the bumpstomps of the lower control arm? Seems like it would serve the same purpose?
Two top out spacers are bad because of excessive droop, which creates extreme cv angles and thus breakage. Using limiting straps lets you control how much the suspension droops. Raising the bumpstops on the lower arms would just reduce suspension travel, that wouldnt do anything to prevent excessive droop.
Droop is the downward travel of the suspension.
The stacked washers that you mentioned doesn't limit the downward travel. It can only limit the upward travel. A limiting strap is needed to limit the downward travel.
hth
hth
I assume you are talking about the Daystar-style lift spacers. Those spacers are providing the lift and are not being used in conjunction with a lift spring. They are on top of a stock spring.
[QUOTE=Bighead;50657666]I assume you are talking about the Daystar-style lift spacers. Those spacers are providing the lift and are not being used in conjunction with a lift spring. They are on top of a stock spring.[/QUOTE
Gotcha, thanks for clearing it up.
09-04-2015 10:27 AM
88runnergomas
07-09-2015 02:12 PM
