New engine steams and water out tail pipe...PLEASE HELP!
I just put in a rebuilt engine. When the engine is warming up it is sluggish and emits steam and water out the tail pipe.
After warm up it runs like a champ (Also no water in oil or oli in water).
Is it possible that I hooked up some of the hoses wrong?
Thanks for your help.
1990 Yota 4X4
3.0 L XTA Cab AT
1990 Yota 4X4
3.0 L XTA Cab AT
1990 Yota 4X4
3.0 L XTA Cab AT
1990 Yota 4X4
3.0 L XTA Cab AT
You should check torques on head bolts first.
If no good, remove head and check gasket.
If you don't , you are throwing away all the dollars you put into the engine.
David
Now be aware that depending on the humidity and temperature you will have condensation and run off of steam out of your tailpipe whenever you start the vehicle up. Until the tailpipe warms up and vaporizes the condensate then you will have it. It is the major cause of corrosion in an exhaust system.
So expect some water to come out when you first start up on a humid cool morning.
thefreq
how does it idle? is it hard to start? (rough idle and/or hard to start could also point to headgasket/head sealing/cracked head problems).
if you have a compression gauge, do a compression test when the engine is cold and see if one or two cylinders are lower than the rest.
Thanks guys. After that first post I got worried and took it to the dealer to verify if the worst had happeded (head not sealed). it idols good and starts right up. Guess that I will know the damage soon enough. Will post next week when I have an answer.
-phatdawg
-phatdawg
has the truck been sitting in high humidity conditions? when i built my first engine, my truck sat for about a month in freezing cold and pouring rain, it shot huge clouds of white steam for the first 10 minutes or so that it ran. most likely condensation in the tailpipe
LOL, after I replaced my engine that I hydrolocked, water was spewing out the tail pipe for a good 5 minutes.
After the initial steam out your tail pipe did it do it again? In other words let it sit til it cools down, then restart, steam = water leak.........
The steam always happens when cold and has happened at least 3 times. It is humid here in Eureka Ca (usually around 66% even in summer, more in winter). Also the engine did sit for a few months while I was working on it.
Anybody ever buy a rebuilt engine from "Rising Sun Engines". They are in Chico CA. I checked the Better Business Bureau and no complaints. Hopefully this engine is OK or fixable.
-Phatdawg
Well you guys have to keep in mind that H2O (water) is a product of the combustion of Octane, let alone any other hydrocarbon. Now it's not enough to visibly see steam coming from the tail pipe, but like you guys said, if it were humid enough, it could easily combine to give off enough water to visibly see steam from the tail pipe.
I have a question. Is this the same gas that was sitting in the truck while you were working on it. Not sure if that would be an issue or not, but something to think about.
sounds like dihydrogen monoxide vapor. http://www.dhmo.org/facts.html
Location: Far western Kentucky (transplanted from central PA)
09-04-2015 09:27 AM
Johntom240
7
07-13-2015 12:18 AM
