new clutch noise
new clutch noise
I have an 89 pickup 2wd and I just replaced the clutch cover, disk, throw out and pilot bearing. Ever since I did that when I drive it clicks. It speeds up with the engine, but when my truck warms up after a while, the sound seems to go away, but comes back after it sits. It sounds like a loud valve noise, but it has to be something with the clutch since it started when I replaced it. It only happens when I am on the gas though. I am hoping maybe it will go away. Anyone had this happen, Thanks in advance.
If I recall correctly, the exhaust pipe bolts to the left side of the bell housing, and just above this is a pipe joint to the exhaust manifold.
Its leaking at or near this joint.
justdifferentials
Just Differentials
14
09-24-2017 09:32 PM
