New Aux. lighting
New Aux. lighting
This weekend I installed some KC daylighters I had laying around.
I thought I would get fancy with the install, and used a opto-cupler instead of a relay. What I didnt know, is the opto-cupler has a 3V drop across it, so there was only 9V getting to the kc's. I also found out that there is only 10V getting to my headlights, with 12V still at the fuse block. Next weekend Im going to get some relays to replace the opto-cupler and get full voltage back to the headlights.
Location: Houston (home), Atlanta (school), Cincinnati (work)
looks pretty good. how stable are they on the bumper? i have mine the same way and they vibrate decently but its never too noticable. i just havent aimed mine, one is aiming on the street and on is way up. ive been lazy!
I just got them aimed last night, I havent driven with them too much, so im not sure about the shaking. They are drilled through plastic and 2 layers of metal, seemed pretty solid.
I used the lights on a over night drive through Jasper Park and they worked fantastic. No shaking at all and awsome light spread. Also, the stock headlights were amazing with the new wirering harness. I suggest anyone who hasnt done this, to do the wiring harness upgrade.
The wiring harness upgrade takes the original headlight plug as a high/low beam signal, then with a couple of relays, supplies the full battery voltage to your headlamps. My lights are unbelievebly brighter now. I suggest this mod to anyone who is still running thier stock headlights.
Were can someone purchase the mod?
One I would like to get the mod and also add some KC's...
Live in deer country and I want to be able to see infront of me....
I made my own wiring harness. Here is a diagram of how I did it.
https://www.yotatech.com/forums/show...ghlight=wiring
Or you can buy one from here.
http://www.4crawler.com/4x4/CheapTri...OnLineOrdering
This upgrade makes an unbelievable difference. And since your re-wiring, you mise well install some KC's while your at it.
Sorry to revive post again..
But I have yet another question...
Anybody ever try putting lights on the Roof Rack Cross Bar?
I dont' use the roof rack and Just wondering if anyone has tried.
If Yes, how did oyu mount them and where did you run the wires?
ashersullivan88yota
01-18-2022 05:37 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
