need immediate help!! permanent marker on paint
Old 09-12-2005 | 09:53 AM
Jboy's Avatar
Originally Posted by northfacer581
really?
I never tried it on perm ink but whenever I get road tar or a good ole dried up smashed bug I bust out the WD40. It really works. I can`t remember who or where I got the idea from but try it and you`ll see. No joke.............
Old 09-12-2005 | 09:59 AM
Jboy's Avatar
Originally Posted by lee
no, he's just being a jerk.
no idea myself, sorry.
WD-40
Known as "the can with a thousand uses," WD-40 protects metal from rust and corrosion, penetrates stuck parts, displaces moisture, and lubricates just about anything. But did you know it can also be used as a cleaner?
THE FIVE BASIC FUNCTIONS:
CLEANS…WD-40 gets under dirt, grime and grease to clean. It also dissolves adhesives, allowing easy removal of labels, tape, stickers, and excess bonding material.
DISPLACES MOISTURE...Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits.
PENETRATES...WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
LUBRICATES...WD-40's lubricating ingredients are widely dispersed and hold firmly to all moving parts.
PROTECTS...WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements.
Old 09-12-2005 | 10:22 AM
Intrepid's Avatar
Lee was this the same guy who got punched by a bum?
Old 09-12-2005 | 12:33 PM
northfacer581's Avatar
Originally Posted by DudeBud
some fine cut cleaner and some lacquer thinner should do the trick
where can i find these?
Old 09-12-2005 | 01:32 PM
  #25
surf4runner's Avatar
DONT use ammonia based solvents on plastic (windex, etc.). otherwise paint thinner should work well. be sure to wash parts after.
Old 09-12-2005 | 04:49 PM
  #26
lee's Avatar
lee
no, sadly.
Old 09-12-2005 | 06:40 PM
  #27
fo_runner's Avatar
One word TOOTHPASTE. Yes, sounds weird and crazy, but it is known to remove permanent marker. Make sure to use regular everyday toothpaste, NOT the baking-soda based one.
Old 09-12-2005 | 06:42 PM
  #28
Gangus2006's Avatar
Clay Bar
Old 09-12-2005 | 07:18 PM
  #29
so whats my best option for removing some spray paint on my tailgate...?
Old 09-12-2005 | 07:29 PM
  #30
waskillywabbit's Avatar
wet sanding w/ 1500+ grit
then clay bar, polish, wax
Old 09-12-2005 | 08:37 PM
  #31
DudeBud's Avatar
any auto parts store
Old 09-12-2005 | 09:24 PM
  #32
straightaxle85's Avatar
brake clean works good too, i had some pernmanent marker(dont ask why) on my truck and i sprayed brake clean on it and it just dissappeared no wiping involved. or electrical cleaner dissolves it like that too.
Old 10-03-2005 | 02:43 PM
  #33
86SR522REEFI's Avatar
gasoline works the herculiner off of my hands
Old 10-03-2005 | 05:59 PM
  #34
is that for my spray paint, or the original thread topic of permanent marker?
Old 10-03-2005 | 06:05 PM
  #35
FingerMan20's Avatar
wouldn't acetone work?
ashamsuddin
17
07-22-2024 04:59 AM
kawazx636
10-06-2021 04:03 PM
ladybugRC
458
08-21-2020 11:41 AM
Toys4parts
09-26-2015 02:56 PM
Obmi
09-10-2015 04:36 AM
