Need Help! Tacoma Front End Question
Old 05-14-2009 | 06:06 PM
i_love_tacos's Avatar
Ok so i was wheelin one day and when i was tryin to climb this huge ledge i heard some metal breakage noises and lost 4WD. I thought it was the driver side CV axle and so i replaced both sides. Turns out they were fine and still no 4WD. Could it be the rind and pinon? i hear no weird noises at all while drving and when put into 4WD.
This is my first time breakin sumthin so I am a bit lost.
thanx...
Old 05-14-2009 | 07:04 PM
dport's Avatar
Guest
Have you checked your driveshaft U-joints?
Old 05-14-2009 | 08:49 PM
BajaRunner's Avatar
How are you certain you have no 4wd? No drive to the axles or just no 4wd light?
If the ring or pinion were screwed up you'd know.... unless the teeth on the ring were completely sheared off that the pinion is just sitting there spinning!
Old 05-14-2009 | 08:55 PM
u-joints are fine.
i do know the driveshaft does spin when 4WD is engaged. front wheels dont move while the rear is. tested it by going up a hill as slow as possible to the point where the rear wheels are digging into the dirt.
Old 05-14-2009 | 09:25 PM
no drive to the axles.
Old 05-15-2009 | 06:58 PM
talked to a mechanic and he suggested the spider gears are gone. sounds about right. whatcha all think?
Old 05-15-2009 | 07:10 PM
Tacoclimber's Avatar
One way to find out... break er open and have a look. If it is the spiders, you might think about re-gearing at this point...
Old 05-16-2009 | 01:33 AM
good idea but im gonna wait till i get a locker to install and just get rid of the spider gears. not sure about regrearing at this point. 4.10s are doing ok rolling the 33s. im going to regear when i do a SAS at the end of the year.
Old 05-16-2009 | 05:25 PM
wunbigtacoma's Avatar
if anything drain some of the fliud if their is metal?
Old 05-18-2009 | 08:17 PM
yup it glimmerd and was nice and shiny oil. haha
time for the locker.
one of the little gears must be sittin in pieces at the bottom of the diff.
can it do that?
lledwod
08-30-2016 02:03 PM
TURBOrunnerNM
07-22-2015 12:01 PM
Avenged
07-09-2015 08:55 AM
Cplmike
07-08-2015 09:47 PM
toyoda8488
07-05-2015 11:18 PM
