need help finding 2 wires for alarm??
hey guys, i have a 2002 tacoma and i put a keyless entry/remote start in my truck this weekend. it went in nice but i couldnt find 2 wires. the dome light wire to turn on the dome light when i unlock the truck and head light wire to flash my lights when i lock my truck and stuff. i know kinda where they are but cant find them, the schematic i have tell me the headlight wire is red/blue on a 16 pin gray connector at fuse block at headlight switch located in driver kick panel, but on the fuse block every connector has a red/blue wire on it and they all look simialr and i couldnt find it. also the dome light is a black/ white wire, located on a 2 pin gray connector at fuse block on driver kick panel, and i cant find that on either, any help as to where these are would be greatly appricated, thanks guys.
Jon
Jon
Jon,
Go to the maintenance section, click on the FSM online manual link (stickied at the top), and spend $10 measly bucks to download the entire, real FSM(s) for your vehicle. The electrical info will be there too.
Bob
Bob
Might also want to try www.the12volt.com and post there, there is a huge amount of info and it really helped me on my alarm and remote starter install. You can see my sig for pics of when I did mine as well but the wiring will likely be different because mine is a 1996.
steve miller
10-10-2015 01:40 AM
Johntom240
7
07-13-2015 12:18 AM
