Need help fast! Re: gears & locker scenarios & prices
Okay I've got a 98 4Runner with 4.10's and am running 32" tall tires. I'm taking off on a LONG road trip and am passing some yards that have 4.30 rear ends with lockers as well as 4.30 fronts as well as just diffs. The rear axle is $460, front is $350, and $150 for just the front diff. I'm hoping I can sell my old axles.
But then I got to thinking... How far off would I be in price from a set of new 4:56's? How about with an ARB or two installed. Thing is, I can do the complete axles, but not gears and or lockers. I'm sluggish now and think my mileage could go back up, and I'd like to move to 33's in the future. Can I get your opinions, experiences, and maybe some $$ figures as well. I'm leaving for this trip in the morning so I need to decide in the next 4 hours!
Go for the full swap, front and rear. Sure it took some work, but in the end I am very happy I did it. Be prepared for the front swap though, that my friend, is not fun.
You should be able to sell your stock 4.10's for a little cash as well.
Definetly get the entire rear axle if you can and not just the third member, that way you won't have to modify the axle housing like I did. Pick up the front diff as well, that price is very fair for a 4.30 front. If you can, grab the ECU and all the wires as well or take the easy way out and order a wiring kit from Inchworm.
It'll take a good bit more money to get the gears and ARB's installed, because you have to buy the gears and the lockers then have someone set up the gears and install the lockers, plus the air compressor for the lockers. I wouldn't set up gears and then go back and set up lockers later because it wouldn't be cost effective, seeing that you would have to open everything back up twice to do each install. My rig drives so much better now with the 285's and 4.30's then when I just had the 4.10's.
polo451
13
11-20-2016 08:49 PM
jerusry
10-19-2015 06:28 PM
coffey50
07-28-2015 11:55 AM
Seattle_Sign_Guy
07-12-2015 01:38 PM
