need help with a chirping noise - 97 4runner
*UPDATE on fix...need help with a chirping noise - 97 4runner
Hello all,
Need help with possible diagnoses before I go to the mechanic. My 97 4runner (4 wheel drive) has developed a noise that sounds kind of like a cricket. When I depress my clutch, it goes away. When I let it out in gear, it returns. When I start moving from a complete stop, the sound gets faster. It does not seem to be coming from any of the belts or the fan. Any thoughts? Does this have anything to do with the throttle body?
TIA
As noted above, I went to the mechanic and my clutch and bearings were damaged. I had my clutch assembly and bearings replaced as well as the flywheel remachined. The 4Runner shifts better than I ever remember it!
All work was done at Protrux in San Marcos (SoCal) for a grand total of 551.00
Thanks for everyone's help.
TIA
I have the same thing, it's the throwout bearing on my truck.
Doesn't cause any damage to the truck, just to your brain from it driving you CRAZY!
Originally Posted by Scofco
There's your hint right there.
Mine makes the same noise if that makes you feel any better. I also just had my clutched replaced less than a year ago and the noise is back already. I think I'm going to have to go to Toyota and see what's up, because it's driving me insane. Not to mention I have a heat shield rattle that I still have not pinpointed
Guys,
I had the crickets and the cure was to change out the manual tranny fluid. If you are going to do that, I highly recommend (i mean HIGHLY) Redline MT-90. Do a search and see my as well as other people's threads on the subject.
Bob
Bob
Originally Posted by Bob_98SR5
Guys,
Bob
Bob
Poncho0206
07-10-2015 07:21 PM
