Need Help with Alarm
i have a 95 runner with a chapman alarm... problem is when i bought the truck 3 years ago i was told that it was disabled now i have had to replace the battery the alarm is now activiated and i have no remote. is this alarm a factory one or aftermarket...? where could i get a new remote or how do i disable it again. thanks .....
Find the alarms ECU. There will be a large plug on one side, then several smaller plugs(2-3 wires each) on another side. Follow the smaller plugs until you find a pushbutton. Push in the button and turn your key to the on position. This will usually disable it. You might just want to remove it. It really isn't hard to do. The main thing is that you reconnect the ignition wires correctly. Most alarms have a starter disable.
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
