Need help with 90 22re
Old 08-28-2004 | 10:50 AM
10cents's Avatar
I have a pickup with the 22re, when I start it up it idles for a few minutes then starts turning off. It will run for about 2 minutes before it cuts off. When I push the gas down about 1/4 of an inch it will rev then drop like its hitting a rev limiter but its only at like 1-2k (no tach). If I push it down any more it will rev up just fine. Once it gets warmed up (about 10-15 mins of driving) it will idle fine most of the time but still cut off occasionally. I replaced my spark plugs and checked the PCV to make sure it had good vaccum and it was fine. Im thinking it might be some kind of air flow sensor or something? Any help would be greatly appreciated.
Oh, I checked the vaccum lines to the cylinders (whatever those 4 lines in my intake are) and there is only supposed to be vaccum in line A at idle (according to Hanes manual) but the Vaccum was in the line next to A not A.
Old 08-28-2004 | 11:37 AM
88yotaboy's Avatar
Check the timing and the idle speed.
Old 08-28-2004 | 11:41 AM
colsoncj's Avatar
How long has it done it? Is the truck throwing a check engine code?
Old 08-28-2004 | 11:52 AM
SoCal4Running's Avatar
How many miles are on the truck?
Old 08-28-2004 | 01:06 PM
10cents's Avatar
Its got 143k on it. Its been doing it for about 3 days since I got it back from the shop. The mechanic that was working on it said "I couldnt find anything wrong with it." I just went to the land fill and it got really bad on the way home, cutting off constantly at idle and it is jumping really bad if im not at WOT. Its not giving me any code. I turned the idle screw thing about half of a turn and it didnt help so I turned it back.
Old 08-28-2004 | 01:53 PM
Check all your wiring connections, including all injectors. Definatly sounds like something is partly unplugged.
Old 08-28-2004 | 02:00 PM
ebtide's Avatar
Sounds like the throttle position sensor to me. Good luck.
Old 08-28-2004 | 03:36 PM
Thats what I was thinking to but wouldnt that turn on the CE light.
Old 08-28-2004 | 04:09 PM
PirateFins's Avatar
cap, rotor, fuel filter, spark plug wires, tps, egr, dirty TB with clogged vac ports.
These are somethings to check.
Old 08-28-2004 | 04:26 PM
10cents's Avatar
Ok, I cleaned the TB but it didnt help. I cant start the motor without it stalling now. If I dont floor the gas it will not stay running.
Old 08-30-2004 | 05:38 PM
Thats gotta be your TPS, either not adjusted properly or just whacked.
Old 08-31-2004 | 12:07 AM
colsoncj's Avatar
My TPS was outta wack, and it didn't throw a check engine code. However when i did check the codes it pulled up a code that the idle position on the TPS wasn't set properly. I would look into the TPS...
JNapolitano
11-14-2019 08:46 PM
Stull
08-28-2015 06:53 AM
ia02
08-20-2015 12:04 PM
PlayAwhile
07-20-2015 12:36 PM
