nedd to replace zerk fitting
Old 05-01-2007 | 10:12 AM
frohbego's Avatar
02 4runner. on the zerk fitting on the front drive shaft (not u-joint) i think i may need to replace that zerk fitting. I noticed just a little grease leaks out and stays right where the silver ball is. Do i need to get a certain zerk with correct thread?
thanks!
Old 05-01-2007 | 10:19 AM
mt_goat's Avatar
I wouldn't worry too much about it, as long as you can pump grease in to the bearings, what does it hurt that a little dab leaks back out? It leaks out all around the bearings too. But yes, there are different thread sizes (metric and standard) for zerks just like bolts.
Old 05-01-2007 | 10:25 AM
frohbego's Avatar
thanks. it should be fine for now... i was worried i might of messed thte fitting up when i pulled my grease gun off it.
Old 05-01-2007 | 10:34 AM
Victor's Avatar
I agree. As long as you don't loose all your grease as it spins at higher speeds - that is it only allows a little to flow back. Also - don't overfill the driveshaft grease points. You limit the ability for the driveshaft to compress if you do that and that could mean broken parts.
kazuya2416
04-05-2024 03:17 AM
TURBOrunnerNM
07-22-2015 12:01 PM
andrewtexas123
07-14-2015 05:29 AM
icentropy
07-09-2015 03:12 PM
wilbertd
07-06-2015 08:39 AM
