My wife on snow . . .
Old 01-17-2003, 07:24 AM
JohnM's Avatar
Eh, an argueable statement when discussing front wheel drive cars. Though I agree with the general idea that the same amount of traction should be available from all 4 corners of the car.
Old 01-17-2003, 07:33 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Originally posted by upndair
Your snows should never ONLY go on the front wheels. Put them on all 4 or don't put them on at all. Putting snow tires (especially if they're studded) on the front tires of any vehicle is about the most dangerous thing you could do.
I fully understand the concept. However, unless you're really hot-dogging, it's quite driveable w/no rear breakaway. I've been driving setups like that (snows on front of FWD vehicles) and contend that, as long as your rear tires have decent wet/snow capability (which both my wife and son's cars have...), you can go suprisingly well. I live in very hilly terrain and the concern has been getting up steep grades. This setup works fine not only going up, but also coming down some pretty slippery stuff.
Ideally, I'd put snows on all 4 wheels. But I ain't rollin' in the $$.
Old 01-17-2003, 08:14 AM
Highland Runner's Avatar
It is true that putting higher traction tires or snow chains on the front of a vehicle only is a very, very bad idea. I live in steep terrain of western NC where we get quit a bit of snow. What happens is, when you go down a hill and brake the front gets better traction than the rear. The rear end then swings around. I saw this happen twice last winter right in front of me. One truck must have spun 3 times around and the car only once. Neither was damaged but had a vehicle been coming up the road it could have been serious. Most car manufacturers also say in there owners manual never put higher traction in the front only.
Old 01-17-2003, 08:32 AM
JohnM's Avatar
It's also a bad idea to put snow tires only on the rear axle. Uncontrollable understeer or uncontrollable oversteer. One is no more dangerous than the other.
I would tend to believe its the driver that failed and not the equipment. Like that dumb*** that I saw a few years ago driving 60 in 8" of snow on the interstate, a mile later was upside down in the median. Not the result of poor tire choice.
Old 01-17-2003, 10:29 AM
  #25
RigRunner's Avatar
some weight in the back would probably help. I would also rather drive in 6" than 1/4".
Old 01-18-2003, 04:28 PM
  #26
keisur's Avatar
Originally posted by Rick F.
Since I bought them at the same place I bought their other tires, I only get charged about $20 each time I swap the tires, including the balancing. Well worth the piece of mind...
I save myself about $1/minute then I guess because I do it myself and they only need to be balanced once in a while, if you get the tires at a reputable place, they will give you lifetime rotate and balance for about $10 when you buy them and then you can have them balanced each season for free. just my oopinion.
Old 01-18-2003, 04:32 PM
  #27
keisur's Avatar
for the reasons you mentioned and the terrain you spec'd I would swap all 4. I don't know anybody that has a 4runner that does this because it wouldn't make 4wheeling very fun in the winter if they did. 4wheeling in the snow is fun, almost as fun as in the mud!
punks_is_4x4
02-26-2016 04:29 PM
4banginRunner
11-13-2015 05:23 AM
Chicken12
10-14-2015 03:54 PM
hiluxinargentina
09-30-2015 05:51 PM
Project90
09-24-2015 11:40 PM
Quick Reply: My wife on snow . . .
