My poor clutch!
My poor clutch!
I recently purchased a 96 4Runner SR5 and I'm absolutely loving it. I'm just kind of bothered by the fact that I have to try to push my clutch through the floorboard to get the switch to let the engine start. That's no exaggeration-sometimes the clutch will be ON the floor and it still won't start until I try to force it through. Is this normal in 4Runners with a manual transmission or is the switch in my clutch worn out?
its exactly what the others just said..
Either its bent and all it needs is alittle bend back and/or adjustment (grab a 12mm wrench and get ur butt under there) OR if you are to lazy then use the clutch start cancel switch...
primordialbeast117
12-19-2015 12:23 PM
smilen724
13
11-08-2015 04:11 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
